Results 16 to 18 of 18
Thread: Joining Wires - What's the best way?
    Jul 2007
    Default Re: Joining Wires - What's the best way?
    jaycar has glue lined heatshrink
    Mar 2008
    correct.^^ unless confident with soldering. just go with crimps and glue shrink. get your self some good crimps and joiners and theres no problems.
    Forum Contributor 1st year Apprentice robk's Avatar
    Feb 2010
    I twist the wires together for mechanical strength, then solder them.
    I normally use heat shrink, but if I have to use electrical tape instead (due to forgetting to slide the heat shrink on first, or running out of it) then sometimes I will put a small cable tie around it so I know that the electrical tape won't peel off over time.
    As mentioned by others, if the wire has enough slack to not be in tension, but also has enough support to not move around too much, then you should have no problems.
    I've been using the twist-and-solder method for many years with no problems at all.
    I also don't like how chunky a crimp connection tends to be.
    For a race car, especially an endurance one, then high quality crimp connections would definitely be the way to go though.
    1990 SW20 MR2 with '5S-GTE'.
    418rwkw @ 32psi of boost on E85.
    289rwkw @ 20psi of boost on 98 RON.
  1. why/how are bots joining toymods?
    By PlacentaJuan in forum Forum Troubleshooting & feedback
    Last Post: 12-03-2009, 03:33 PM
  2. Q on joining the toymods group
    By bje10s in forum Toymods Car Club Membership and Feedback
    Last Post: 15-01-2008, 08:29 AM
  3. Replies: 16
    Last Post: 10-11-2007, 06:36 AM
