Results 16 to 23 of 23
Thread: Supercharge 18RG
    Feb 2012
    Australia
    Default Re: Supercharge 18RG
    Sounds more painful then using the SU's
    NooB 3TGTE swapped RA40
    ✨Rahgo2:Turbo Boogaloo✨
    ^^^ what he said.
    I have a brand new Malpasdi reg to suit as I was turboing a twin side draft mikuni 2T back in the day.
    HKS used the solexes in their turbo carby 18RG kit btw so has been done to good effect
    Feb 2012
    Australia
    Well where would one begin finding said parts to modify some solex's? I have a few spare solex's lying around I can play with.
    Get a spare carby and pressurise it to 7-9psi. But you really should do it with a pressure regulator.
    Or even do a hydrostatic test with water, but make sure you have a pressure gauge in there as mains water pressure can still be 60psi or more.
    This at least would let you see if the shaft seals can handle the pressure. And if a float collapses.
    Feb 2012
    Australia
    I'm not quite sure how I would go about doing that sort of test when I'm on a budget.
    Forum Contributor Domestic Engineer
    Small hand pump, or a low pressure regulator from a pneumatics supplier to hook up to your air compressor. Only be a few bucks worth.
    Having never done or driven a blow through setup, I still don't see the benefits outweighing the brilliant simplicity of a suck through setup when on a budget.
    MA71 - 7MGTE - 340RWHP
    Feb 2012
    Australia
    I never said it had to be blow through, I'll do which ever setup up is easiest/cheapest
    Also, I don't have an aircompressor yet...
    Go suck thru then, so much simpler and TB before the SC also solves a few issues.
    Simple plenum onto your twin carb manifold. A single solex should flow enough air with the right venturies, but dunno if you'll be able to jet it large enough? Outside my experience sorry
  1. Any1 Ever Supercharge A 2TG?
    By toyota81 in forum Tech and Conversions
    Last Post: 09-11-2012, 02:36 PM
  2. Supercharge a 2.2 4y (na) motor or engine swap
    By steve_t647 in forum Tech and Conversions
    Last Post: 22-11-2005, 05:22 PM
