Results 1 to 11 of 11
Thread: Best close ratio box for 2TG?
    Feb 2007
    Default Best close ratio box for 2TG?
    Can anyone help with what the best close ratio 5spd gear box to use behind a 2TG motor?
    Jul 2007
    Default Re: Best close ratio box for 2TG?
    if you want a close ratio 5spd then why dont you rebuild the standard T50 with a TRD close ratio gearset?
    Feb 2007
    I have a T50 gearbox so that would be probably a good way to go. I typed TRD into google but it was not clear where you would buy a TRD close ration gear set from?
    Aug 2009
    I bought the TRD Spec 1 kit; 2.63 first 1.89 second standard third fourth fifth, from New Zealand for about $1200NZD about 3years ago. Have since found this kit, which is suitable for slightly modified engine with 4.3:1 diff and is not made anymore. There are other brands available with similar ratios. TRD Spec 2 kit is closer ratios throughout and is more suitable for highly modified engines. Cost of type 2 kit averages $2400 USD. One place is Tokyoseven for Spec 2 kit. If I find other places later will list them for you.
    http://www.tokyoseven.com/T7/product...30&language=fr
    Here is another I found a while ago:
    http://www.greenline.jp/catalogue/bc...ory=drivetrain
    Feb 2007
    Cheers thanks! I guess Albins may even do a close ration gearset for a T50 as well
    Aug 2009
    Albins is another option. A former employer put a Albins set in his 4age powered clubman and found third made a whining noise when cruising on flat road, have heard from one other person has same noise in his sprinter. Don't know if your car will be road/ track or just track use, track use noise shouldn't be a problem.
    Jul 2007
    possibly straight cut gears causing the noise?
    Aug 2009
    No they were Albins helical cut welded gears and only did it in third with both people. Other than the noise were a great set.
    Feb 2007
    Application is in a classic rally car so noise is not a problem at all! I will investigate the Albins option
    Aug 2009
    I bought a TRD set from RHD Japan. Excellent to deal with and the gearbox is brilliant
    http://www.rhdjapan.com/trd-close-ra...et-a-ae86.html
    Rgds, Willofan
    Jul 2007
    saw the green celica out there at MCM yesterday
  1. Close Ratio Gear set for W5# ??
    By Cameron_Datto in forum Tech and Conversions
    Last Post: 24-12-2005, 09:41 PM
