Results 16 to 22 of 22
Thread: 2tg/3t hybrid problem
    Jan 2009
    Default Re: 2tg/3t hybrid problem
    Whats the pin height on those pistons
    Junior Member Domestic Engineer TA22 GT's Avatar
    There at the shop now but i think its 35mm
    Any update. Did you find the issue?
    Sep 2007
    Georgia
    So let me get this straight,
    Sep 2007
    Georgia
    Quote Originally Posted by anty109 View Post
    Hi I just bought this 2tg engine that has a 3t crank in it and 1mm over size pistons so 86mm bores. I turned the engine over bye hand on the stand just to check i got the timing chain right and that the engine turned over with no interference.
    All was ok. Started the engine up and all was good then a tapping noise started up. I rechecked the timing chain and made sure the cam caps were tight. Started engine again and it was ok no noise. When i rev the engine the tapping noise comes back. When the head was off i had double valve springs installed and the head was checked and everything was ok. The valve reliefs on the pistons looked like they had some markings on them but the valves were fine so i thought nothing of it.
    I used a cometic head gasket H0894SP7043F which is .043'' thick. apparently engine was running fine and was used for a couple of races and the head was pulled off to check compression ratio for a possible turbo conversion. and then i bought it and reassembled it.
    does anyone know what the noise could be or what to check from here.
    So let me get this straight, you installed the 3T crank and failed to clearance the walls of the block to account for the rod interference (30mm from oil pan edge = down 30mm making a 38mm long by 17mm wide funnel) and the 16mm round by 2mm deep rod bolt, top of bolt interference to the block next to the piston bore?
    That is how it was done in the "Old days" when using a 2t series block instead of a 3t series block. (Carboy 1983)
    See, the 2t block had to be used in japan because if the block was changed the amount of paperwork required and fees attached made changing to the 3t block an expensive process. the solution was to clearance the 2t block to account for those interference points, this may be where your tapping sound is coming from. Skirts of the piston were also modified.
    73GTV,
    Good info, i think u could be right. Im interested to hear the outcome of this..
    Sep 2007
    Georgia
    You are welcome, I would have posted the image from the magazine but felt it would be less legal troubles down the road.
  1. 7mgte ideling problem and pressure problem
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 25-05-2008, 06:43 PM
  2. GZ20 Hybrid EBC problem
    By phil in forum Tech and Conversions
    Last Post: 20-02-2008, 05:19 PM
  3. Hybrid Electronic Boost Controller problem.. not boosting past 4psi?
    By bathurst-91 in forum Tech and Conversions
    Last Post: 09-04-2006, 09:24 AM
