If you could tell us a few ideas you have, for example what is main use of vehicle, what gearbox and diff particularly diff ratio you will be using.3t conversion is not a necessity but will give a increase in torque and a extra couple of kw's.
To give you an idea I have a TA22 which in near future am building a 2T/3T conversion with wiseco 86mm pistons using approximately 10.5:1 compression ratio, can bore up to 89mm. Will be using a cam with approximately 288 duration (am looking at a couple of different regrind profiles). Head will have mild porting, size is not always the best idea but rather shape and finish, with 3mm oversize valves and multi angle valve seats. I have a TRD gearkit for the gearbox and a tomei lsd with 4.3:1 new diff gears. The car will be my daily driver and weekend club level motosport events. Hope this gives some idea.
