Results 1 to 14 of 14
Thread: w58 in MZ10
    Tasmania
    Default w58 in MZ10
    I had a quick search and couldn't find anything.
    Just wondering if anyone knows for a fact whats involved with replacing the stock Auto and replacing it with a w58 in my MZ10.
    From what I've been told I need the box, pedal box, cylinders, MA61 manual tailshaft and a clutch. I'm wondering if there is any other stuff I need to buy and is it pretty much a straight bolt in swap, ie. the w58 will bolt straight up to my MTEU bell housing or do I need the supra one aswell? Cross member and stuff?
    Jayson
    Junior Member Backyard Mechanic kugzs's Avatar
    Default Re: w58 in MZ10
    judging by the add in the parts wanted section for a m>w bellhousing, i'd say that the W58 will not bolt straight up to you MTEU bellhousing.
    Also, you might have to get a manual centre console (at least i had to do this for my TA22)
    Tasmania
    I will have to modify my consol, that isn't a problem. Mainly just wanting to know everything I will need to get it to bolt up, as for clutch MA60 clutch yeah? What about flywheels and shit?
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Hi mate
    Ya need a complete manual conversion kit from a MA61 supra.
    bellhousing
    flywheel
    clutch
    slave cyl
    master cyl
    pedals
    clutch line
    spigot bearing
    release fork and bearing
    W58 gearbox with mount
    Dunno about tailshaft
    I have all this stuff here if your interested. PM me
    1994 GZX90 Mark II 1GZ-FE V12
    yep as said, MA61 manual stuff will work (I have done it). (Clutch pedal can come from a xA6x).
    You will need the Manual Front half of the tail shaft as it is ~80mm longer in the manual (a manual RA60/RA65 tailshaft [not SA63] should also work )
    Note that all the required parts can be ripped out of an RA65 or SA63 Celica, apart from the flywheel and bellhousing. This will make it much easier to source the bits as wrecked MA61's don't exactly grow on trees, especially manual ones.
    If you're asking if your existing auto bellhousing will work on a W58 then the answer is no; you'll need a M -> W5x bellhousing. The only (relatively) common sources of those is the MA61 and non-turbo MA70 Supra.
    You will also need to cut the floor to suit the box.
    The hole in the tranny tunnel on the auto's is slightly further forward compared to the manuals.
    RA6X has the wrong clutch slave and clutch hard line; SA63 is correct in that regard.
    SA63 tail shaft, gearbox shifter position (most far back) and gearbox crossmember will not work (they are different to the MA61 stuff).
    So ANY RA6x/SA63 celica clutch pedal and clutch master and brake pedal will fit. SA63 clutch slave and hard line will fit. RA6x front tailshaft section can be used? (not sure on that myself!)!!!
    And as Norbie said, M->W55,W57,W58 bellhousing and flywheel (MA61, MA70 non turbo)
    And as Cruz said you will have to cut the floor for the shifter (you should get a MA61 shifter position).
    Tasmania
    Awsome thanks for all your help! only bits I was really worried about were the bell housing, flywheel and tailshaft but thats all cool!
    Low Down Style Domestic Engineer Johnzoku's Avatar
    queensland
    sorry to dig up an old thread but...
    when installing the clutch pedal do you cut a square out of the sound deading to fit the clutch box into or leave it as is... since its got the shape of the clutch master in the sound deading on the firewall on the inside anyway?
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    when i did my mx73 i left the sound deading on there
    queensland
    thats what i did, i assume that if the holes are already in the fire wall and there a provison in the kick panel for a clutch pedal... then the hole thats already there must be like that for when they factory fit a manual
    just wasnt sure.
    thanks.
    I removed that section of deadening, as its already precut.
    You want the clutch pedal to be hard up against the firewall.
    queensland
    ahh true... ill have to go and fix it then... i didnt see that mine was precut at the time but im sure it will be.
    thanks.
  1. W50 vs W58 - need info to do the swap on my RA28
    Last Post: 13-04-2014, 09:53 AM
  2. W58 stuff
    By Big rob in forum Tech and Conversions
    Last Post: 27-01-2008, 08:43 PM
  3. Clutch Slave Cylinders (W58)
    By e30-323ti in forum Tech and Conversions
    Last Post: 12-01-2006, 11:36 PM
  4. W58 Supra gearbox Input spline count info
    By Esteban in forum Tech and Conversions
    Last Post: 29-12-2005, 01:11 AM
