Results 16 to 19 of 19
Thread: No Boost Hi-Flowed CT26 ???
    Junior Member Domestic Engineer 1200det's Avatar
    Default Re: No Boost Hi-Flowed CT26 ???
    Thanks for the Ideas !!
    I`ll check the Comp wheel nut tonight , The more i look at the turbo the more i think there couldnt be anything major wrong with it as there are no chunks out of any wheels and its wasnt making a horrible noise when driving back home.
    Although the wategate wasnt stuck open as such could it be a weak wastegate that at the first sign of boost is just opening ???
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    Damo, bring the turbo a round to my place, I will check it out for you.
    cheers Chuck.
    Going with the theory of the Wategate , Ive fitted the turbo back up again and went for a drive and a horrible noise when coming on boost.
    Remove Turbo Again
    Can clearly see the front and rear wheels had lightly been scrapping on the housing with just a second of boost and now i can clearly see when spinning the wheels
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    south australia
    well, i would definetly be taking it back to the place that did the job and explaining what is happening....
    you should be able to get it fixed for free
  1. tt soarer over boosting
    By kremsra28 in forum Tech and Conversions
    Last Post: 07-06-2006, 09:34 PM
  2. Boost Leak Tester
    Last Post: 01-06-2006, 11:25 AM
  3. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
  4. Replies: 22
    Last Post: 15-03-2006, 01:24 AM
  5. TA63 boost spike problem
    Last Post: 28-01-2006, 11:44 AM
