Results 16 to 19 of 19
Thread: MX32 overhaul
    Mar 2008
    Default Re: MX32 overhaul
    Did those camira racks come in power though? Local u pull it here has a couple theyre all manual.
    They sell rebuild kits for power racks... and there is much talk from the Holden/Ford boys about converting some of the older vehicles using power racks. Perhaps you need to expand your search?
    Apr 2011
    did a little measuring on the weekend...
    x7 is almost 100mm wider than the x3 from rail to rail so thats a no-go.
    bolt spacing is about 25mm different too (not that thats a huge issue anyway)
    so back to the drawing board i guess.
    will now look into simply mounting a rack to the factory crossmember. i'll get the drop saw and mig out and mock something up
    Apr 2011
    so anyway it's been a while...
    ended up cutting up a the stock crossmember and welding the mounts to an s13 crossmember, then using s13-jz engine mounts.
    i am no longer doing my mx32 project as i have too many others, but a friend is doing pretty much the same conversion in his mx32.
    tie rods ended up on a dumb angle using x3 LCA's and struts with the s13 rack, so all s13 gear is going in the front. (coilovers, lca's and brakes)
    staying 4 stud and smallish brakes to clear 15" meshies.
    plenty of room for exhaust around the steering too unlike x7/x8
    next thing will be starting on the rear diff. will be using a taraga diff so nothing fancy there.
  1. Overhaul Kit for AE101 Superstrut Calipers
    By vvti16v in forum Tech and Conversions
    Last Post: 28-10-2008, 11:18 PM
  2. RA28 Overhaul! and Celica Badges....
    By MartyK in forum Tech and Conversions
    Last Post: 01-04-2007, 03:50 PM
