I had a Cressida with A340e. To check if the solenoid valves were working I looked for an old computer in the rubbish and pulled out two of the front panel LEDs with long leads. I then slid the wires up inside the terminals on the computer. I then took it for a drive and you can see the when the leds glow whether the solenoids operate in the sequence they are supposed to.
The second test is to remove the plug from the computer and apply 12 volts to the solenoid connections. If they are working you can hear a definite click.
The third item is to check the fluid. My A340e was supposed to use Dex2 and I was told I could use Dex3 but it tore the fibres off the clutch packs and completely clogged the filter giving it strange changing patterns until it wouldn't move at all because the filter was fully clogged.
