hardweld a set? Web camshafts offers hardweld on the cams they offer. If you have a spare pair of gen 1 cams you can likely have them made into whatever you want.
Gen1 3SGE uses the same bucket/shim arrangement as the 4AGE... so making a few assumptions based on 4AGE, I'd say you can run a "264 type" cam on the stock ECU while keeping some idle. Again, basing this on a 4AGE... don't forget to add an appropriate amount of compression. On a 4AGE 264 cams work very nicely with static compression ratio of around 11 to 1
