Results 1 to 15 of 16
Thread: 4AGZE in TA22 Thermostat Housing
    Tasmania
    Default 4AGZE in TA22 Thermostat Housing
    Hey Guys,
    A few years back i bought a 72 Ta22 that had a 4agze put in. After driving around fairly often and finally checking, it seems it does not have a thermostat setup.
    Does anyone have any information on the setup of a thermostat on the 4agze? As the Tassie winters almost make it undrivable (especially when the windows fog up on a -2 degree morning and i need to wind the window down to clear it!!!) haha
    thanks
    Kolby
    Default Re: 4AGZE in TA22 Thermostat Housing
    something like this might help mate..
    http://www.rollaclub.com/board/topic...cooling-guide/
    Feb 2010
    Auckland
    I had the same thing when I got my TA22 with a (nearly complete) 4agze conversion.
    Started with this
    Changed it to this using the AE92 housing
    hope that helps
    Jul 2007
    sam-Q does kits also
    Mar 2011
    ae82 or ae92 remote thermostat housing will have it sorted. or if you want something pretty, see SamQ, his stuff is nice (i have his RWD 20v kit on my TA22).
    SHEPPO..
    Tasmania
    Thanks guys, You are awesome! Will get this sorted in time for winter now
    Thanks again!
    Tasmania
    hmmmm.... question. How do i find Sam-q's kits?
    kolby
    I recently released a cooling kit:
    http://www.sq-engineering.com/upgrad...rsion-kit.html
    it's for 20V however I had extra housings machined because I think these can be readily adapter to 16V as well. Using a 90 degree barb out the top with a 90 degree hose and the OEM steel pipe cut down to join to the housing it should fit near on the same. Sure it won't be as cheap as using the 16V gear but it's compact and neat. I plan on trying this soon to see if it indeed does work.
    Tasmania
    Thanks Stolic. This looks good. Guessing it heads to the radiator at the bottom there?
    Where did you but the adapter or kit from?
    Feb 2010
    Auckland
    Quote Originally Posted by kolby View Post
    Hey kolby,- Correct, the bottom pipe would connect to the lower radiator tank. It's not a "kit" as such... just adapted the thermo housing from the AE92 4age (that part usually sits on top of the gearbox from memory) so a wreaker or someone on here might be able to find you one. Then just make up some pipes to connect as in the pic. The pipes I've run in the pic were just thrown together from spare junk so I could see how it would all fit as I had to work around my ITB's. Currently making proper lines out of fancy steel braid for added blings
    Tasmania
    Hmmm cool. Sound like the go. Ha, yes a bit of bling is always good!
    So the remote thermostat housing what exact corolla will i find them on? Any ae82/92 or am i needing to find one that has the 4age motor in it?
    Feb 2010
    Auckland
    Mine is off a 4AGE from an AE92... one from a 4AGE from an AE82 can be used, but would be mounted differently as one of the pipes different.
    http://www.toycrazy.net/tech/compari...ae-thermos.jpg
    Tasmania
    Ok thanks. I have managed to track down this one from i think an ae92.
    Should do the trick hopefully.
    Any advice for piping or mods that you can see would be great
    Feb 2010
    Auckland
    If you compare your pics to the link I posted, you'll find that your one is the AE82 version. I can be used, but its a PITA to mount as one of the water pipes points out the side instead of the back. This means that pipe would be pointing at the block instead of the back of the engine (where it takes water from the back of the head) so you cant mount it on the block inline with the waterpump, unless you can get a tight 90' bend on it, but I think you'd be pushed for room.
    Tasmania
    Quote Originally Posted by Stolic View Post
    Yep I asked the guy when i picked it up and he said ae82. I see what you mean about the 90' bend. I figure i may aswell pop it in unless i can track an ae92 one down but no one seems to have one.
    Was thinking of setting it up either like the one in this link http://www.toymods.org.au/forums/thr...tures-included or i'll try set it up similar to yours bit with a solid 90 or 110' bend.
    So just trying to get my head around the setup. The main hose leads to the bottom radiator? Then there are two that come out at a similar point. Big one leads to water pump? The smaller one leads... Top radiator hose? and then i have the one coming out at a 90' bend. Guessing that leads to the heater core?
    hope that made sense haha?
