Results 1 to 7 of 7
Thread: How much boost can GZE Pistons hold
    Default How much boost can GZE Pistons hold
    All you fellas running a Turbo 4AGE/GZE with GZE Pistons, how much boost are you guys roughly running?
    If you could, could you also post up your power figures please!
    perth
    Default Re: How much boost can GZE Pistons hold
    Running 22psi on mine. With stock inlet manifold limits.
    390hp at wheels.
    they are tough motors. But a bad tune will kill anything.
    Jul 2007
    Cheers for the answers guys, That link really helped. Cheers trdee!
    I have never heard of a non-detonation related failure with ZE pistons, I know someone on this forum has run 30 PSI reliably.
    Mar 2012
    I have broken a few sets of stock AE101 pistons, with as little as 18psi, but it probably came down to bad tune and/or oil starvation.
    I have never heard of someone breaking a stock rod cept due to bearing failure while drifting
    390hp @ 22psi is pretty impressive! I only got 277hp @ 23psi with 280' cams! My 25psi beams doesn't even put down numbers like that!
    perth
    thanx man, tho it has a pretty big turbo and bigger cams. but still not the power it should be making (as you can see its massive fast drop at 7300rpm) as the stock bigport manifold is pretty shit, im surprised i got that much power out of it, seeing how small those 8 runners are.
    only have this print out, we played with cams after and got 389.
    on bp98
  1. will my 2j hold up?
    By Barrington in forum Engine & Driveline Conversions
    Last Post: 09-09-2012, 05:19 PM
  2. EVC 5 doesnt hold boost
    By normality78 in forum Tech and Conversions
    Last Post: 14-05-2008, 05:59 PM
