He will need to find the automatic transmission offered in the AE7x or AE86 with the 4AC engine, as the bolt patterns and flexplate locations should be the same. I don't know if these were available in the Uk, I do know they are scarce... but around in the USA (and Canada?) He will also need to source a flexplate from an MR2 because the MR2 used the 4AGE, and so the flexplate has 8 holes drilled
As to the power... your friend will want to boost the engines compression about 1/2 to one full point, this will help increase the low end response. I would not swap in a performance cam..... too much lost low end
