Results 1 to 5 of 5
Thread: What spark plugs should I use for my 4agte?
    Aug 2014
    Default What spark plugs should I use for my 4agte?
    I've just bought a set of nz coil over plug type coil packs and a dizzy blanking plate to upgrade the original coil setup on my 16v 4age turbo. Can anyone recommend a spark plug that would best suit?
    Murvz
    Jul 2007
    Default Re: What spark plugs should I use for my 4agte?
    I just used standard gze plugs. No problems up to 20psi. You can go one heat range colder if you want....
    perth
    i run bcpr6es
    same deal, run them with over 20psi and cdi ignition and have been faultless.
    Aug 2014
    Cheers lads.. I was thinking along that line but was unsure if they were compatible with the nz coil packs
    Jul 2007
    yes they work fine. i am using 1zz coilpacks (same shit) on my setup
  1. high hp 2jz spark plugs?
    By al167 in forum Tech and Conversions
    Last Post: 17-10-2010, 06:47 AM
  2. 4agte spark plugs
    By HKS 16T in forum Tech and Conversions
    Last Post: 07-03-2010, 05:09 PM
  3. Spark plugs for 1MZ-FE
    By 2JZR31 in forum Tech and Conversions
    Last Post: 01-08-2008, 05:35 PM
  4. oil in spark plugs??
    By newbien in forum Tech and Conversions
    Last Post: 27-01-2006, 12:22 AM
