Results 1 to 14 of 14
Thread: 4agte spark plugs
    Oct 2007
    Default 4agte spark plugs
    Hi all
    just checking out whats the best spark plugs to run on my 4agte
    cheers Chris
    senior backyard mechanic Grease Monkey legend's Avatar
    Default Re: 4agte spark plugs
    i like ngk have been great plugs with only 1 failure "so far" with the 4agte u could run a slightly colder plug depending how u drive it
    building my 4agte ae82
    i run the standard ae92 recommended plug from ngk up one heat range to 7
    gapped to .7
    perth
    i use ngk bcpr6es.
    from memory i use bcpr7es, gapped to 0.8mm. they are fired by LS1 coils.
    4agte Sprinter - 11.7 @118mph WSID
    2.45 @ mount panorama
    1.56 @ eastern creek, 1.10 @ wakefield
    1.24 @ oran park GP
    2.00 @ Phillip Island
    S.A
    Im using NGK's In the 7 range and out to 9 depending on what im doing / fuel im running etc.
    gapped at 1.1mm
    Sep 2009
    i use NGK's in the 7 range .7 gap
    but..
    Quote Originally Posted by 30psi 4agte View Post
    gapped at 1.1mm
    Your using those MSD coils with built in ignitors i take it? or something similar.
    Would you be willing to supply some info on them like if you had any problems with them or not ect?
    My gze daily is getting new coils and computer, and at this stage ill be going with the msd units. Just curious to know of any problems/issues using them.
    thanks
    case
    i like the v-grooves. BCPR7EY i gap at 0.8mm. stock ignition.
    Quote Originally Posted by cri_ag View Post
    I run the same and same gap. No problem with spark up to about 22psi.
    My KE25 thread
    Junior Member 1st year Apprentice Grippy's Avatar
    Quote Originally Posted by fixeruperer View Post
    i use ngk bcpr6es.
    I run the same, no issues, EMS ignition,
    Oct 2007
    i have autronic SMC with a HKS spark amp
    thanks for you imput guys
    BCPR7ES-11, stock ignition, only ever had it up to 12psi at the time. Planning on still using the same ones for new setup with more boost.
    Oct 2009
    As far as i know silver is the best conductor of electricity and then copper, so i'd go with a silver plug to suit with the right gap. Just don't go platnum or iridium
    Sep 2009
    plat and iridium are worth more because they last a lot longer than copper ones, you are correct that silver plugs conduct better. ideally gold would be the best but i doubt anyone makes them.
    Really nothing wrong with copper plugs, you should pull them out and at least check/regap them when you service it so, cant beat em really. You wouldnt notice any difference even on a dyno unless under extremly well monitored conditions, with a highly tuned engine me thinks.
  1. Wasted Sparks VS Sequential Spark
    Last Post: 08-01-2018, 12:19 AM
