Pattymac, I see where you are coming from. The factory utilizes spot welding, this keeps the heating to a minimum and avoids the expansion problems. You can hire a spot welder from the good hire shops, or you could buy a cheapish one off the interweb. They are heavy suckers though and next time I have to borrow my mates I will be slinging it from the engine crane.
Tack both ends, tack middle, spot both ends, spot middle then fill in the gaps alternating spots from one side of centre to the other, Just take you time ad if the tempo starts getting up take a smoko break, or use a damp cloth to pull the het from the metal.
If you use Tig or Mig, do spot welds, absolutely no need for a continuous seam weld. Silica Bronze works well for panel steel, requires a lot les heat to accomplish the task and is ideal for homemade spotwelds.
cheers Chuck.
