bushings are shot?
hey guys i dont know if this is a common thing or not but i got a carona st141 wagon (manual) and when im driving down the road the back seems to sway from left to right and especially when you change gears and release the clutch?? i dont know what to do can any one help thnx
bushings are shot?
something is moving around back there!!
get under and see if you can see any perished or broken bits....
and failing that, ask Rona how to make ot handle on the old pacFTW
(ok ok.. it'S late
rear shockies possibly? Stand at the back of the car and bounce the rear up and down. Get a nice bounce happening then let go, the shocks should react instantly and settle the car. If it continues to want to go up and down then there stuffed
i had this in my ke70. the bushes for the panhard rod were shot. allowing the body to move side to side on the diff.
took me bout 45 mins to fix the problem and 10 bucks for the bushes. you should check them out
Originally Posted by The Witzl
heu yea iv already replaced the pan hard rod bushes with urathane ones so its not themOriginally Posted by slide86
ok ill do that tomorrow im in the middle of a head gasket renewell so ill fix that firstOriginally Posted by bansheebuzz
i just had a look under the car and all i could see was the lower suspension arms have really worn rubbers and i could twist them do u think that could be it because replace ment ones are a good $70 thnx guys
um id have to say yes!
lol all done replaced with urathane bushes and it feels perfect
