Results 1 to 5 of 5
Thread: AE92 Cruise Control: Speedo cable Pulse generator OR ECT Speed Sensor / Sensor Rotor?
    Jan 2007
    Default AE92 Cruise Control: Speedo cable Pulse generator OR ECT Speed Sensor / Sensor Rotor?
    I Recently got myself a Rostra Cruise Control unit for my JDM Corolla FX. Car is early series AE92 and AFAIK has no VSS.
    Kit includes Magnets that I'm meant to JB.Weld onto driveshaft which I don't like the sound of.
    Looking at ToyoDIY I noticed that JDM Automatic cars (with ECT gearbox) had a Speed Sensor / Speed Rotor which Rostra said they could interface with to get a speed signal (i.e. w/o magnets).
    I could be asking a stupid question here but. . . . Can the Speed Sensor & Rotor from the Automatic be mounted to manual gearbox to function as a speed pulse generator?
    Toyota P/N:
    Speed Sensor: 89411-17020
    Sensor Rotor: 89414-12010
    Nov 2011
    Default Re: AE92 Cruise Control: Speedo cable Pulse generator OR ECT Speed Sensor / Sensor Ro
    Just find the spd wire on the ecu
    Its a violet wire with white trace
    Jan 2007
    OK; so I guess I bought this < attached > for nothing. .
    So how does that (speed wire) work; i.e. what does it take the speed signal from?
    Nov 2011
    I think u did buy it for nothing
    The cable speedo spins the shaft inside the speedo
    There is a reed switch inside the speedo that sends a signal down to the ecu
    This wire is normally for cruise control
    Jan 2007
    All good; I appreciate the info. That's what these Forums are all about, to live & learn. At any rate it was only $50 so it could have been worse. . .
    I don't suppose you know much about Relays? No-one's even looked at my other post* let alone commented on it. . .
    * < Alternative for fried JDM Powerfold Mirror Relay / ECU >
  1. R154 1jz abs sensor to Soarer speed sensor 2?
    By 1jz_manual_project in forum Tech and Conversions
    Last Post: 10-08-2011, 12:21 AM
  2. RA 60 control arms/ ra40 speedo cable
    By little ra40 in forum Tech and Conversions
    Last Post: 17-01-2010, 08:10 PM
  3. Right Angle Speedo Drive or Electronic speed sensor
    By Bazooka in forum Tech and Conversions
    Last Post: 27-09-2008, 10:37 AM
  4. Running a speedo without speed sensor
    By 81rolla in forum Tech and Conversions
    Last Post: 21-10-2007, 04:46 PM
