Hmmm...
Plenty of questions...
The Accuspark instructions say the module cannot be used with low impedence coils such as for electronic ignition:
I think this means the MSD coil will not be suitable. Given the original Bosch coil worked fine and it all came crashing down with the MSD coil install I think this is plausible.Before fitting your AccuSpark it should be noted what type of ignition system is fitted and that a suitable coil is correctly fitted.
Only coils of more than 1.4 Ohms of resistance are suitable. Low resistance and electronic ignition coils are NOT suitable and will invalidate any warranty.
If I were you I would put the accuspark dizzy back in with the Bosch coil and see if it still works.
As for the engine refusing to run with the old optospark unit only with the vacuum advance plugged in I wonder if there is a significant vacuum leak from the diaphragm unit on the dizzy?
I would be looking to a cheap MSD6(AL) for some extra spark grunt since you are only running single coil and adding cylinder pressure artificially with a turbo.
Jason
			 3T ignition woes
 3T ignition woes
