Results 1 to 5 of 5
Thread: Oil burning woes
    California
    Default Oil burning woes
    I was finally able to fire up my 3tgte, problem is, it's spitting oil through the exhaust (also rough idle due to vacuum leak). I pulled out the plugs and as soon as I took the #3 plug out, smoke started coming out of the plug hole. Any other ideas beside that I may have a bad ring?
    Ryan
    Feb 2012
    Wa
    Default Re: Oil burning woes
    Broken ring LAN and or melted piston is common on these engines
    Tallahassee, FL USofA
    What's the compression?
    It is NOT spitting oil out the exhaust. It is condensation, look at it.
    Smoke from recently stopped engine, while not common, is completely normal and not a sign of anything except a valve open & heat rising.
    Ring land.
    Nov 2009
    is it oil? or is it a mixture of consensation/fuel and carbon from the inside of the exhaust, do a compression test, and make sure you do a wet compression test too.
    California
    Compression Test
    ----DRY WET
    #1 - 90 110
    #2 - 90 120
    #3 - 90 120
    #4 - 80 120
    Ryan
  1. gze burning oil + smoking
    By old_mr2 in forum Tech and Conversions
    Last Post: 06-08-2010, 02:15 AM
  2. Burning oil 4AGTE
    By turbo_gze in forum Tech and Conversions
    Last Post: 27-10-2008, 12:10 AM
  3. 4age burning oil?
    By chris_85 in forum Tech and Conversions
    Last Post: 01-03-2006, 04:52 PM
