Wiki is WRONG! The Honda does NOT use a Aisin AZ6 the case design is COMPLETELY different. See below... the S2000 transmission is on top the other photos are all AZ6 related(2nd pic is J160, 3rd is butchered Miata... Yes Miata, and the bottom view is the S15)
The actual case on the J160 is a bit stouter then the case used for the RX8, Miata, and S15, if you look carefully(in above photo) the J160 has a spine along the top of the case the others don't have.
Here is a recent photo from LEEN showing the S15 bell/front case mounted to an RX8 transmission
the "current" AZ6 user is Toyota with the GT86/FR-S...
in fact the GT86 uses 5 of the 6 gear ratios that the S15 used...
