Results 1 to 4 of 4
Thread: 4age diagnose please
    Aug 2012
    New South Wales
    Default 4age diagnose please
    4age big top dropping idle to 500rpm and clunking noise coming from below the car. Clucking goes away with clutch pedal in but idle problem remains.
    new clutch bearing?
    and would the clutch affect the engines idle or ability to rev?
    Default Re: 4age diagnose please
    What's the cold idle speed like?
    Dec 2008
    Wellington, NZ
    With the car stationary and the engine idling...
    - Clutch out, throwout bearing not under load, gearbox input turning
    - Foot just pushing lightly on clutch pedal, throwout bearing under light load, gearbox input shaft turning
    - Clutch in, throwout bearing under heavy load, gearbox input shaft not turning
    Clunking noise like a crescent spanner in the clothes drier, that goes away when you push the clutch in, would most likely be something in the gearbox not happy. Does it make the same noise when you are driving ? If the noise goes away when you just lightly touch the clutch pedal, it is most likely the throwout bearing.
    Idle speed has no connection to the clutch or gearbox.
    Cheers... jondee86
    Feb 2014
    Gauteng
    Hi
    Yes have the same problem on mine, its the releaser bearing...will just live with it till I do the clutch,as hiro mentioned what is your cold idle speed? Was the idle speed always like this? try cleaning the throttle body with some carb cleaner
  1. 3S-GTE Losing water/Overheating. Suggestions to diagnose cause?
    By OnAll-FOUR in forum Tech and Conversions
    Last Post: 29-03-2010, 10:56 PM
  2. Reward Offered - Help me diagnose a Clunking/Knocking noise from Satan
    Last Post: 15-01-2008, 02:36 AM
  3. How to diagnose a faulty proportion valve?
    By Johnzoku in forum Tech and Conversions
    Last Post: 08-09-2007, 11:04 AM
  4. Diagnose my 4age, with videos!
    By Mitchee in forum Tech and Conversions
    Last Post: 02-08-2007, 07:14 PM
  5. trying to diagnose a fuel pump or FPR problem
    Last Post: 07-08-2006, 10:21 PM
