Results 1 to 3 of 3
Thread: 3rzfe Flat spot
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    Default 3rzfe Flat spot
    So ive gone back to a toyota. Its a 02 hilux 4wd with a 3rzfe (love this engine to death). Has about 220***km on the clock.
    My problem is it has a flat/hesitation spot when taking off and changing between gears and seems sluggish.
    Prime example is doing 100km in 4th then change to 5th and it drops power and wont go past 90km.
    Things ive done so far
    New plugs
    Fresh 95 fuel
    and FUEL SYSTEM CLEANER / CONDITIONER
    Also removed the air flow meter and gave it a clean with CRC mass airflow sensor cleaner
    Next iam thinking is fuel filter and then a fuel pump.
    It feels likes its starving of fuel or air. Once it gets going it seems ok
    Nov 2008
    queensland
    Default Re: 3rzfe Flat spot
    and anyone have the test procedure for the airflow meter if there is one?
    I would changer the fuel filter. Check the leads and the coil pack is not grounding out on engine rocker cover. You're coil pack could be wearing out causing one cylinder getting less spark. Also hook up a scan tool and check that you're O2 sensors are okay. I had same trouble with my 08 hilux 2.7 after, plugs, fuel filter turned out to be a worn out O2 sensor. Sensor 2. I replaced both and now is fine. If you are near Brisbane to Ipswich or Gold Coast, I have a ob2 scan tool and can come and help if you want.
  1. Replies: 26
    Last Post: 05-01-2014, 09:47 PM
  2. ST215 flat spot
    By scottlefevre1981 in forum Tech and Conversions
    Last Post: 17-10-2009, 07:06 PM
  3. Stumble off idle when cold, flat spot
    By leideno in forum Tech and Conversions
    Last Post: 27-07-2009, 06:28 PM
  4. 1JZ Flat Spot... Help??!!
    By Danners in forum Tech and Conversions
    Last Post: 01-08-2007, 09:32 AM
