Results 1 to 3 of 3
Thread: Blacktop Flywheel
    Aug 2013
    Auckland
    Default Blacktop Flywheel
    Is it possible to get it machined to be lighter then the stock 5.9kg? The cost of an aftermarket one is a bit out of my budget. Would like low 5kg or late 4kg.
    Dec 2012
    Default Re: Blacktop Flywheel
    Not a lot of room to move on the BT item. Some may tell you to never machine a cast iron flywheel.
    Low 5kg? how much do you think 500 grams will benefit you?
    The BT unit is a quality piece, less meat is more weakness.
    nuts Grease Monkey
    auckland
    I didn't have a BT fly at the time of swapping in a ST engine so i machined the ST fly to similar fashion as BT with cutouts between clutch bolts and turned the underside to less than the BT weight. I think 5.3kg. then had it balanced with the clutch pressure plate (which was way out). But for less than the price of balancing it I couldve just bought a BT fly. It is light enough that it stalls out easily at the lights so throttle before clutch is a must.
    -Mark
    E2 + E7 fan
  1. 16v 200mm vs 20v Blacktop Lightened 212mm FLYWHEEL
    By Matt-AE86 in forum Tech and Conversions
    Last Post: 26-11-2006, 04:18 PM
