Results 1 to 9 of 9
Thread: 4agze injectors in 20v?
    Aug 2013
    Auckland
    Default 4agze injectors in 20v?
    I have a 20v engine and have a set of gze injectors with fuel rail. Would they fit onto the silvertop? What else do i need to make them work as they are bigger then the stock ones and in good nick.
    Thanks
    Jul 2007
    Default Re: 4agze injectors in 20v?
    you need a custom fuel rail as the 20v engine uses side feed injectors, and 16v engines (which your gze injectors are from) use top feed injectors.
    Aug 2013
    Auckland
    I have the 4agze fuel rail, would that work?
    OR the other option is to use a set of lancer GSR 390cc ones, would they be a better option?
    Jul 2007
    i dont know but i doubt it. give it a shot
    Are you unable to get hold of any other side feed injectors?
    I'm using 550cc 3sgte side feeds in my blacktop and they work fine.
    I can't see how it would be worth modifying the fuel rail to fit top feed ones even if it was possible.
    Feb 2010
    Auckland
    if you're keen hit up Bazda @MRP... he's just machined his black top inlet mani to take top feed (1200cc i think) injectors.
    Tho probably cheaper to just get some sidefeeds in your case, unless you decide you need massive fuel
    Melbourne Victoria
    you can also use 2jzgte 1s as well they are side feed
    As above, 1JZ and 2JZ both work.
    No top feed injector will unless you go out of your way to adapt it. Fitting a turbo?
    wa
    gen2 3sgte injs are side feed 440cc and cheap as chips.
  1. can a 4agze run on 195 cc injectors?
    By slide86 in forum Tech and Conversions
    Last Post: 11-06-2010, 07:31 PM
  2. 4agze injectors
    Last Post: 25-06-2006, 12:50 PM
