The car is Manual (W58)
I have GX81 mark 2 and the fuel and tempeture readings all work but the speedometre doesn't. What do i need to do to get it to work ? Someone please help![]()
look at back of dash and see if theres a round lug where a cable would slide into
if there is then u need to get a cable speedo drive for yr manual gbox
if there is not then u need to check the speedo sensor on the gbox and then check the wiring to see
if its actually wired up to the dash
when did u buy it
is it a white one
I've got a jzx81 digital dash that will work
Yer i don't even think its wired up to the dash lmao. Bought the car last month in, its Midnight Purple.
Yep, as the guys said you first need to make sure if your speedo is mechanical or electrical. For either you need to make sure that as dumbass mentioned, to make sure all the bits are there and that they are plugged in properly.
Happy to help with wiring diagrams if thats the issue.
ok cool
I had a look at one half finished afew months ago down southport way
GX81's ran mechanical speedo drives, either run a cable otherwise I have a spare digital speedo (JZX81) dash.
