Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: 1JZ Cressida was running rough, now won't start.
    Jan 2013
    Angry 1JZ Cressida was running rough, now won't start.
    Hey everyone. Hope someone can help me.
    I have a '92 Cressida with a 1JZ-GTE (non-vvti) engine and manual transmission which I have had for about 5 years now. About a week ago it started running a little rough under load. Now it has started struggling to start altogether. Sometimes it will run for a few seconds then just die. The spark plugs are platinum iridiums and were changed only 12 months ago. I also checked the fuel pressure and sensor connections and everything looked OK there too. The check engine light has not come on so it is hard to diagnose.
    Any ideas and suggestions would be appreciated. Thanks in advance.
    BK Grease Monkey bk_'s Avatar
    Default Re: 1JZ Cressida was running rough, now won't start.
    Which spark plugs? make/code.
    OEM ECU?
    4-row or 2-row ECU?
    Jul 2013
    victoria
    rough under load is often due to coilpack breakdown....
    I had this issue with my car (JZX81 ECU), it turned out to be the stock ECU blew after the stock caps went and it took out the ECU. Mine put up code 14 once i checked the codes (lack of iGf signal meant the car wont run).
    Jan 2013
    The plugs are NGK Laser Platinum BKR6EP-11. The ECU is stock. I have ordered a full set of new coil packs so I will let you know how I go once they are fitted.
    Nov 2011
    I would pull ecu out and take covers off it and check inside it for leaking caps like others have mentioned
    also does the check engine light come on with just ignition switch on and engine not running as it might not be hooked up at all
    Jan 2013
    Yes, the check engine light comes on without the engine running and stays on for a second or two after the engine starts, then goes out. I will see how I go after replacing the coil packs. I hope it isn't the ECU.
    Quote Originally Posted by phoenixbaron View Post
    I had ignition issues too, but it was funny what ended up being the problem.
    Around 12 months ago, I replaced the ignition plugs/connectors with new ones. However, I soldered the pins onto the wires, aswell as crimping them. Unfortunately, one of the crimps broke the solder, so ignition was intermittently cutting out.
    But anyway... I replaced coil packs with new ones... didn't change much. But I only discovered the source of the issue after buying the coil packs. Re-soldered the pin and problem gone.
    Second issue is that I was still running the same original spark plugs since the engine transplant, since 2005 until 2 months ago. Replaced with BKR7EIX, and I re-gained responsiveness under vacuum.
    Jan 2010
    Quote Originally Posted by dumbass View Post
    I would do this! ECU's for 1J's are notorious for capacitor leakage...(just had same issue with mine)
    Oct 2009
    They all do it, something about dodgy knock off caps being sold to Toyota back in the day.
    Jan 2013
    Thanks for all your help. Will take a look at the ECU. Have just noticed quite alot of soot coming out the exhaust. I am guessing this is a result of the engine running very rich. Could this be a dodgy oxygen sensor or catalytic converter?
    Jul 2013
    victoria
    could just be over fueling trying to compensate for whatever your problem is...
    Nov 2011
    toyota probably didnt expect people to still be playing with their cars after 15 to 20 years
    they expect u to take them to the tip after 5 years
    Jan 2013
    I guess it is all trial and error until it is running properly again.
    Hello the only things I know about this stuff is the crank angle sensor and cam angle sensors/wires must be in good condition and
    THE SAME POLARITY swap the wires on either and engine NO GO
  1. 1jz running rough please help
    By scotty626 in forum Tech and Conversions
    Last Post: 25-02-2014, 03:10 AM
  2. My first GT4 Rough Idling- won't start!
    By Emrarrr in forum Tech and Conversions
    Last Post: 31-10-2013, 11:19 PM
  3. 1uz running rich/ rough
    By KLR16V in forum Tech and Conversions
    Last Post: 18-03-2013, 08:46 PM
  4. GE running rough
    By ke-70-ge in forum Tech and Conversions
    Last Post: 08-03-2006, 08:48 PM
