Results 31 to 45 of 50
Thread: IS200 and 3UZFE
    Default Re: IS200 and 3UZFE
    yeah ive got a sc430 engine 6speed loom and ecu i can buy. just seeing if that would work
    Nov 2011
    just get an early 3uz much less hassles with everything unless u have shitloads of dollars to fix and sort out the fiddly bits
    the security is easy to sort out if its old school key chip and reader
    it only gets complicated when its the smart key which in aussie Toyotas only came in after 07 08 ish in 200 series landcruisers
    so basically anything with key button start will prob have smart key which means u need 4 ecus to talk and link up before engine will start
    most cars with a normal key in ignition can be worked out by flashing the immobiliser chip if you have no keys
    why not just put an ls3 with a 6 spd auto in an is200
    fits in nicely and would go much better and probably cost the same hehehe
    so I really hate NO as an anwser... I found this guy that has found a way to reprogram a chip for the key. so all you need to do is send him the ecu and he will send you back a key chip programmed for your ecu. Facebook the cartune company . So I have contacted him and Ill see what he says.
    Nov 2011
    he is kelvin
    wait to see what engine u end up with and go from there
    I can progr keys too for a price so pm me and ill give u rough prices depending on what parts u get with it
    and George can do it too and he might be able to bypass immobiliser if its early 3uz
    if engine has smart key then it gets very complicated and not worth doing unless u get front cut
    and then u will have a shitload of mess under the dash
    ideally I would get a 3UZ from a gs430 and 6 speed.. that what I want.. there is one selling down in melbourne. it is still in the chassis. its a 2005. Soemone would have to tell me what I would need out of the car and I would negotiate getting it all as a pack. buy I would need a list of the non obvious things so I could pull it all out.
    Nov 2011
    I doubt its smart key
    so best of getting engine wiring
    and all wiring behind dash
    or atleast get the steering column and key and key reader and if there is an immobiliser box get it and the plug on it
    its prob fbw so u will need accelerator pedal and pedal plug
    hard to know what else without looking at a workshop manual
    so best of getting everything under dash
    May 2010
    Moscow
    slipper86 it's rhd smart key gs430
    it needs AT LEAST 89784-30010 id code box, 89990-30040 smart key control module, and probably some other things but that's enough I think
  8. #38
    Nov 2011
    just buy the whole car
  9. #39
    yeah well now I know the conversion can be done Im going to buy an auto IS200 (for fck all) and start looking around for a donor car. ie see if there are any at wreckers or importers. pity you are not down this way dumbass, actually i dont think any good wiring guys are down here now days
  10. #40
    so as I posted earlier I have been offered a cheap 3uz with "6speed" ecu and loom I just got a pic of the ECU number to see if it worth getting. What can you tell me about this guy. ok so the pic wont upload. grr here is the part number
    89661-50590
  11. #41
    May 2010
    Moscow
    Slipper86, we tried many times to help you but ok, just buy that crap and feel free to contact me or dumbass when you do realize no one's able to bypass its security
  12. #42
    May 2010
    Moscow
    Slipper86 I just can't help your strong will to learn things the hard way. Go buy that crap. Feel free to contact me or dumbass when you do realize no one can bypass the security in it.
  13. #43
    lol.. just talked to dumbass on the phone.. hahha he has told me the models to look for and recommended a 1/2 cut. I am at ease knowing things can be done. even if you guys will match my keys for me. Im looking for an early model without smart key thanks to your advice george
  14. #44
    Nov 2011
    its more the fact that u need to run all the modules for the key
    so I guess it can be done but u will have to run half the gs430 dash wiring and modules in the is200
    maybe even buy a 1uz vvti and with money u save put it towards a good exhaust and stuff to bring it close to 3uz spec
  15. #45
    marty from tas mobile mechanic has his contact in Japan atm and will get prices for me.. Im looking strongly at the vvti 5speed auto 1uz. He has wired a few of those up before and also says its a better option.. 3 against 1. Ill take the pros advice on this one
  1. Replies: 4
    Last Post: 08-03-2006, 09:28 PM
