Results 16 to 24 of 24
Thread: Which Turbo for a 2t/3t cammed engine?
    Junior Member Backyard Mechanic Ashh's Avatar
    Nov 2012
    Default Re: Which Turbo for a 2t/3t cammed engine?
    In the next 3 hours there's either going to be a "It was so awesome" post or "There's a conrod sticking out of the block" post.
    E85 and 15psi here we come
    You have to try pretty hard to stick a conrod through the block on one of these...
    Good luck!
    Jason
    Nov 2012
    So... it was awesome. Dialed the timing up a lot once it was on E85, and chucked a boost controller in. We had a bit of a problem getting the boost controller to up the boost with it only getting to around 145kpa (6psi?), so..
    yoink
    Who needs a wastegate anyway?! (we did have the megasquirt set to cut spark and fuel if it got up to 190kpa so that we wouldn't grenade the engine)
    The turbo immediately started pumping out around 170kpa (10psi?) at around 4k rpm, however from then on the ignition system couldn't create a spark no matter how high we set the dwell and if I shifted up then the clutch just slipped... soooooo had to put the boost controller back on and it seems to work quite nicely with around 150kpa (7psi).
    Now I just need to work out how to get a Coil on Plug or wasted Spark setup working with my Megasquirt 2 and maybe get a heavier clutch and we'll be on our way!
    Just out of interest does the 3tgte clutch fit a 2t flywheel/gearbox?
    EDIT: oh yeah and I really should sort out putting a filter on it
    Junior Member Domestic Engineer Hurricane's Avatar
    Quote Originally Posted by ctrain View Post
    Mine does that too Dan, if i give it the beans through every gear it flys straight to 4500-5000rpm and stays there but it picks up speed, i thought it was the clutch but i cant smell it even after a good flogging, my setups using a hall effect instead of points and an old optospark 500N, i was thinking off going all out and get an MSD 6AL2. I was told mine has a stock cam too, i havnt really tested the engine to see its pros and cons, i will though once i pay rego.
    mines due to shit coils, ive got ls2 coils to put on, just been lazy and building to many other things
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    my first turbo t series was a 2t with no gate, worst i did was crack a pistion at 30psi HAHA
    10 psi at 4000rpm seems so laggy? a t28 should boost up alot quicker
    3tgte clutch is larger, same size as a 1ggte series 1
    i run a allot 3tg item atm with 1g clutch
    i did run a 1g flywheel before that and should have some at home if you need one?
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    http://www.toymods.org.au/forums/tec...0-gearbox.html
    my reply to a 1g flywheel and clutch into a t50
    cheers, dan
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    Nov 2012
    Damnnnnn 30psi. What sort of advance where you running?
    It is laggy but I have a really aggressive NA cam on it at the moment which I really don't think is helping, not to mention a 2" exhaust.
    if I use a 1g flywheel will I need a w series gearbox? - this is all pissing in the wind as well as I want to get it engineered before I make it faster
    no as per my last post (see the link above) i have fitted a 1g flywheel and clutch into a t50 bellhousing.
    you will have to get a clutch disc made with a t50 sline on it, as the w series is larger.
    somthing around 20 advanced from memory. i can look at the table when i have the laptop connected next and see
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    id swap the cam out before you do to much more tuning then, other wise you will have to retune again
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
  1. 3T-C Turbo engine
    Last Post: 24-02-2008, 10:13 PM
