Welcome aboard Stinky!!!!
I'd love to be able to assist you but SV21s and 3S engines are not my forte.
seeyuzz
river
PS: This post has turned me into an "Automotive Encylopedia"!! Hehehehe, I wish.
Hi all, im a forum first timer so take it easy on me? Hehe. Also planning on a 3sgte transplant for my grandpa sv21, anyone know of someone doing it? Or any advice, i would love you forever. Cheers, Dean.
seeyuzz
river
im in the same boat as river!!!
or am i in the same river as ur boat?![]()
cheers scott
74' KE26 4dr Wagon, the daily, aka tha sak wagz.
I guy on the old forums did it to his SV21, take a look there,
Cheers Trent
1977 Toyota Corolla KE30 1GGTE http://www.toymods.net/forums/showth...post7372821977
1987 Ford Falcon XF S Pac
that o-so familar search button is your friend![]()
check out the old forums too,
thats all
welcome aboard
ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph![]()
NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES![]()
whats the gee-ooo with every one having chicks in there avatars
1980RIP NATHAN BRETT DEAN2007,
mine was on the old forums, there is one pic still hosted
http://forums.toymods.org.au/index.p...t=0#msg_422204
if not more info can be found under the gallery section of www.novaauto.com.au
i'll put it back up in the members rides soon. it has a much better looking engine bay now![]()
Hey camrygt?
Looks nice, any chance of more detailed pics? That would be awesome.
Currently the only 3sgte half cut i can find is in brisbane.![]()
Hoping to find one in melbournen soon.
Cheers!
theres a fella by the name of Dean, here in WA thats done the 3SGTE into SV21 conversion, im not sure if it matters, but i dont know what gen the motor was, or any of that stuff.
his name on here is "_Shadowz"
PM him, im sure he'll be willing to give up some info, if your lucky, maybe even for freeehehehe
Eldar.O.
how does a 3s-gte in a camry go compared to say a celica (considering there both pretty much same car) i guess it would rought come down to the car's wieght wouldnt it?
and would it be fair to say that the camry wieghs more?
officially sv21s weight 1170kg mine with everything done after conversion, subs, fuel etc went 1350kg which is still reasonably light for something with 170+ FW kw''s on a basically standard gen3 motor
ran 13.8 sec 1/4mile at 106mph, 2.4 sec 60 foot with stock 195's on the front, stock engine etc low 13's should be possible with a better launch (best on the night of 2.2)
here are a few videos I found that were hosted on the old toymods a long time ago
www.novaauto.com.au/camryvids
100km is vertical on the speedo and boost is the digial gauge on the left peaks about 12-13ish. Thats what a stock 3sgte in a sv21 will go like.
I might be able to get my hands on a gen3 3sgte loom and ecu, I can probably get a E153 box as well all in NSW though
Try Andrew Vibert (forum sponsor) for a motor, ecu, loom and box. Should be about $2500 or so for a Gen 2. Half cut from an ST185 surely can be too much more than that. I think prices for ST205 half cuts are around the $8000 mark, not really worth the extra for a few more neddies which can easily be more than made up for with a pair of cams, hi-flo'd turbo etc. Actually i think Andrew has a Gen2 at the moment with a high flo'd turbo for $2200 with ecu and loom. He is in Victoria.
eek my complete-brakes ST205 frontcut was $3800 delivered about 2 years ago with air/ water intercooler etcOriginally Posted by o_man_ra23
I am pretty sure I can get hold of a gen 3 motor ecu and loom for under $3500
Hmm... I think i will have to talk to you more when the time comes for the SA23 to get new muscles. I think that halfcut price was from the SSS automotive website. They may be a bit on the exxy side tho.
Crazy vids camrygt? Any chance of seeing some up close piccies of everything slotted in?
Still a few concerns in the back of my mind, seeing more detail would probs put them at ease. Let me know if you need my email addy?
Cheers, Dean.
I can get pics of whatever but it depends what your concerns are?
the main things that arn't a straight fit are....
passenger side gearbox mount for E153 gbox (use GT4 one)
speedo for E153 box (sv21=mechanical E153=electric) (I swapped the gauge in cluster)
Drive shafts for E153 box to camry splines (V6 camry inners bolted to GT4 outers)
selectors need a small bush for the mounting point (1 hour with a grinder and welder)
Air to water IC core needs bonnet to be massaged with a hammer slightly.
clearance to cluch master is minimal and touches under load hasn't damaged anything in 60000kms has about 12mm clearance to start with but motor strains the rubber mounts just a little under load.
the usual ECU wiring, bigger fuel pump etc mounting water pump for IC....
