Not sure if this helps but would seem to me that it would fit with minimal massaging of the trans tunnel and you'd need a custom gearbox x-member
http://users.tpg.com.au/users/loats/...earboxes2.html
Hi have a 1jzgte fitted in a ra23 and wanting to fit r154. Anyone some this and if so what's involved.
Thanks for the link master
Have you done this conversion ? Does the fire wall need modifying? The bell housing looks larger or deeper which I think might hit the firewall.
I've not done it mate. I'm sure there are some 23/28 build threads where this has been done (maybe Sheepers?) and some minor relief of the firewall/trans tunnel was needed, but nothing massive.
All depends on where the engine is mounted; in my case it needed quite a lot of massaging
RA23 - Twincharged
JZZ20 - Daily
So cut out the entire firewall and trans tunnel and make and weld in new one?
Easy as pie.
Sorry Mmissos for misleading you.
Kedderz. I'm just sorry.![]()
No need for firewall moving, just notch where the slave cylinder and gear selector are.
Depends on how far back the engine is mounted and the position of the r154.
RA23 - Twincharged
JZZ20 - Daily
here's a good link for an R154 into an RA(??) that I've looked at many times.. (putting one in my TA22 sometime)
http://www.1stgencelica.com/viewtopi...=1129&start=15
looks like he got away with minimal beating of metal.. but as said, it depends alot on engine placement.
Thanks guys.
Gonna do it.
I have one in my 28, on the back of my 1j.
As kedderz said, it will depend heavily on there your engine is mounted.
basically I needed to "flatten out" the the bumps in the tunnel - the tightest area is where the big square section of the box sits.
I didn't think it was too bad.
There are probably pics in my build thread, but on what page I have no idea.
Stew
