Alex,
As long as you can find a gen2 3sge, you can just swap over the wiring loom to the mr2 one. If you can't and have to use the 5sf, you'll have to swap the loom & ecu & do some rewiring. go the 3sge option - much easier
Toby
Hello everyone, my first post here. My gf got a 91 MR2 3SGE non turbo, she ran out of oil and blew the motor. This MR2 is Japanese import, I live in Canada, hard to find the right engine, we have 5SFE engine North America models. I have searched the forum, some ppl said the only difference is ECM, wiring harness, intake, exhaust manifold and a few things. Would it fit her MR2 as long as I switch all the old parts over? I found two 3SGE here, no luck finding MR2 3SGE. Thanks in advance Alex
Alex,
Toby
Hi Toby, Thanks for your quick reply. I found a couple Celica 3SGE here, basically I can use the MR2 old parts and quick swap, correct? My GF did a research, she said the Celica 3sge has less horsepower compared to SW20 3sge, is that true? As far as I know the block and head are the same, the difference is fuel management, intake and exhaust etc, not sure about that. Thanks Alex
just make sure it looks the same year or model as the mr2 1 and not out of a st165 model ,you need the engine out of a st185 celica or later. st202 is the gen 3 motor etc
The ge has the same hp regardless of celica or mr2 providing your comparing engines of the same year. (You dont want one from a st162 celica 85-89)
90-93 ge had 160hp
94-98 non vvti had 180 autos supposedly have 170.
Obv a gen2 from a 90-93 would be easiest as you should be able to hunt down the correct mr2 3sge loom to wire it up.(oops misread and thought you had a 5s, but as you alrwady have a 3s then yeh. Just get another gen2 3sge from a celica and swap as Z ute said.)
Alex, grab a Celica 3S-GE from a car as late as your MR2, no earlier.
Sit the two engines side by side and start swapping bits over so that you have all the MR2 bits on that Celica engine. This includes intake manifold throttle body and every conceivable electrical probe/sender etc.
Having done this when you put the engine in the MR2 and connect it to the MR2 ECU it will actually start and run!
Many foolish people assume that all the sensors etc are the same, they are not, some having different voltage needs and some having different resistance values. Use the Celica items at your peril and expect to be sitting around for months scratching your head wondering why the engine will not start and run.
MS51Crown Coupe,
Trouble guys is that we never got 2nd gen 3S-GE in north-america, neither in the celica or MR2 so all he has acces to is 3S-Ge out of an ST162. After 1990 all we got was either 5S-FE or 3S-GTE.
Check your import yards mate, not the local breakers. You even have a better supply of Japanese engines than we do, and that is saying something.
MS51Crown Coupe,
