Results 16 to 20 of 20
Thread: t40/t50 backend swap
    VAASA / FINLAND
    Default Re: t40/t50 backend swap
    W50
    different type, different splines at bought ends.
    this can be fit with adapter to youre AE86 bell and use yoke or driveshaft from this car. + transmission crossmember from this car.
    this transmission is also a lot stronger than youre T50
    - Celica TA-22 -74 2T-G Turbo
    - IQ 1.0 -09
    - Lexus IS250 -06
    Mar 2012
    cork,ireland
    would i be better off with this box, just make an adapter for the bellhousing
    VAASA / FINLAND
    World is full of different choises and opinions...
    Google W50 adapter or like that.. BRD also sells that years a go.. but its not mine choise number one.
    - IQ 1.0 -09
    - Lexus IS250 -06
    Aug 2013
    Quebec, Canada
    I swapped an early (pre-1975) T40 rear shifter housing on a late (AE86) 22spline output shaft box.
    You just need to swap the 3 shifting rods and everything else bolts up
    Rods difference
    Inside the case
    Bolted up
    all clean (with late shifter housing next to it )
    Only thing to bare in mind is that the T40 shifter has no lock for reverse so if you pull hard enough going out of 5th you could (very hardly but you could) pop it in reverse although a lot of grinding noise will probably prevent you from doing so
    KE20 1974 <- Sold -> Thread
    AE95 1990 <- 4A-GZE daily driven wagon...
    Mar 2012
    cork,ireland
    thanks bermy, i might not have to go this route, but good to know if i do
  1. 2jz swap into an rx7
    By rx72jz in forum Engine & Driveline Conversions
    Last Post: 11-07-2009, 03:34 AM
  2. possible to swap between AFM's on the run?
    By RAd28 in forum Tech and Conversions
    Last Post: 31-01-2006, 08:33 PM
