Results 1 to 8 of 8
Thread: rn85 hilux efi pump install
    Apr 2011
    Default rn85 hilux efi pump install
    hey guys, doing a 1uz swap in my lux, all is going well but i would like some input on what people have done to run efi as these come with carby engines.
    i am outting bigger fuel lines in, but i was just wondering what people have done in the way of fuel pump setups. in tank? surge tank?
    i have all the gear lying around to do any setup, just wondering what works best. pics would be great too!
    thanks.
    Apr 2007
    Default Re: rn85 hilux efi pump install
    What size fuel lines are you going to ?? I would think 5/16 is probably the standard size line & if so will be plenty unless you are running some massive turbo's too ..
    The Guy that I bought my Hilux off used a EFI Holden rodeo tank & it works Very well & no messy surge tank etc needed .. I still had to modify the fuel filler a fair bit as it didn't take much to get it to flow back when filling, but the tank & pump etc all work's very well, just has some New brackets from the chassis holding the New tank ..
    wa
    I'm just running an external walbro mounted near the chassis rail at the bottom of the tank into some standard diesel fuel lines(bigger lines)
    It surges if you give it shit under 1/4 tank but since it isn't turbo i don't mind and just keep it above half a tank
    Can get pics if you want
    Nov 2011
    when I did my 1uz in my rn90 I pulled out the fuel pickup for the carby tank
    one pipe is return one is feed
    I cut the feed pipe short and clamped on an efi pump from an r33 rb25det
    then I put a big hose clamp around the pump and the return pipe and the pump was solid as
    the rb25 pump is small enough to fit back down the hole in the std tank
    took me 20 minutes as I had to drill hole in top and poke wires thru then had to araldite hole and wires
    mine only had surging probs bugger all fuel in the tank and never gave me any pobs for 8 years
    Apr 2011
    yeah i thought about hanging a pump on the stock hanger, the fuel lines just look a little small is all. i thinking about pinching the efi tank from an RZN lux
    Nov 2011
    I contemplated brazing in new fuel lines too but then just tried the orig ones which are 6mm
    so if its going to stay std 1uz then that will be fine, I never had probs running those small lines
    Put a 4runner tank in mine. pretty well a straight fit and comes with the pump
    Jealousy is a curse
    Apr 2011
    Cheers guys, I have decided the efi tank is they way to go.
  1. Coilovers for a 1989 Hilux RN85
    By 289hilux in forum Tech and Conversions
    Last Post: 10-10-2012, 11:25 PM
  2. Need Help: 1GGZE into RN85 Hilux
    By infotechplus in forum Tech and Conversions
    Last Post: 11-12-2006, 08:00 AM
  3. Will RN85 grille fit on my 86 hilux ?
    By quicknissan in forum Tech and Conversions
    Last Post: 19-10-2006, 07:08 AM
