Results 1 to 7 of 7
Thread: Coilovers for a 1989 Hilux RN85
    V8 motavation. Grease Monkey 289hilux's Avatar
    Oct 2007
    Default Coilovers for a 1989 Hilux RN85
    Has any one seen a kit or know of a supplier that could do coilovers for the front of my Hilux.
    Something like this pic I found from the states would be good.
    Cheers.
    Injected 5.0L FORD power in HILUX is the only way forward!
    See my ride here: http://www.toymods.org.au/forums/sho...246#post601246
    Add Lightness! Grease Monkey spectral's Avatar
    Default Re: Coilovers for a 1989 Hilux RN85
    I would be interested in this as well. I've looked into using a similar system to my Clubman (but heavier duty) on my RN90 to get rid of the torsion setup.
    It appears simple on paper, new heavy duty upper suspension control arm (again modelled off the clubman) with standard ball joint (or one with same taper as stock), bolted to brackets welded to the top of the chassis rail. Coilover top mount would be straight forward once you work out the correct angles for your coilover.
    The issue is sorting out your suspension geometry: caster, roll centres, bump steer etc. If you don't get it right then you are going to have some pretty quirky behaviour.
    So if there is a kit that already has sorted out all these issues, would make life a lot easier.
    Westfield Clubman SEi - 4AGE Blacktop, T50
    RN90R Hilux XtraCab - VT V6 (yeah yeah) ,4L60-E, 3.583 LSD
    Oct 2007
    Thanks for the info. Will have to ask them if the do out of the state work as I am in Vic. Cheers.
    Jan 2012
    bay of plenty
    How did you go with the coilovers, did you manage to source a kit, i know this thread is old, but was just browsing through cheers
    Oct 2007
    Quote Originally Posted by monaro427 View Post
    I have been looking hard still cant find a kit. I cant belive there is not something available. So many bag these utes. Mac Donald bros do a top controll arm for $700.00. That is just crazy.
    Anyway I bought a pair of ex NASCAR top controll arms in as new condition with screw in type (moog) ball joints from good old Ebay for $130.00 delivered. What a bargain.
    The ball joint alone reatail for $200.00 plus.
    I hope to end up with a setup like this.
    All I need to do now is buy a pair of QA1 coil overs and fit it all up. Sounds simple I know
    Cheers Richard.
    Apr 2007
    I'm curious what makes you want to go the coil over setup, as the torsion bar set up seems pretty good ??
    I havent really looked into it, but i would imagine you would need to strengthen up the top shock mount a fair bit & maybe the lower arm mounting point too ??
    Just relooked at your user name & i'm guessing the torsion bars are getting in the way of 2 exhaust pipes ...
  1. changing the gear ratio's in hilux diff.
