Results 1 to 13 of 13
Thread: Justification for Oil Cooler on 4age
    Dec 2009
    Default Justification for Oil Cooler on 4age
    Hey all,
    I got a new motor from a mate of mine for my ae92, and noticed that it didn't have provisions for an oil cooler. I would need to swap the sump and sandwich plate over but I do have everything I need.
    I was wondering how difficult it was to replace a gasket if there was one in the sandwich plate?
    Would it be worth installing the oil cooler. My car is used as a daily/weekender project car.
    Thanks in advance.
    ZZT-231 Toyota Celica SX
    Oct 2009
    Default Re: Justification for Oil Cooler on 4age
    Quote Originally Posted by trd_st184 View Post
    Unless your tracking the car, no
    Mine never went over 100c on the street, could get it to 110c flat stick but that's nothing to worry about if your running any half decent brand name oil
    On the track I was hitting 130c+ which is bad though.
    Dec 2009
    thanks mate. How hard were you going to get it to 110c? Would a hot day effect the oil temp quite considerably? I am curious to see what sort of temperatures i'd get with the oil cooler under the same circumstances.
    Jan 2012
    Finland
    Well,considering that the low-end 4A-F have a cooler as STD I quess that factory justified the expense fitting it.
    Sure,the engine will survive without it but since you can get the parts from any Corolla why not to install it?
    Oct 2009
    Australian market option;
    Which model sandwich plate do you have, the OEM model that bleeds into the sump? By the way these have an O-ring to seal them off to the block and are usually quite reusable
    oregon
    Quote Originally Posted by MorGo View Post
    my all-trac has the cooler... but no other USA model 4AF powered AE9x came with an oil cooler standard... I can't speak to other markets.
    Concerning an oil cooler... it is well worth the money ($400.00 give or take)
    Jan 2012
    Finland
    What!? Here when summer degrees rarely exceed 25ºC the oil cooler is standard equipment!
    Maybe it's the Germany market that forced the cooler.
    Many car manufactories would be
    happy without the German no speedlimit Autobahns! The demand of full throttle 2 hour autobahn driving is far away from in city driving..
    i personally wouldnt bother with the PITA factor of fitting the oil cooler for a daily/weekend project car.
    A lot of effort and fucking around on an engine that really doesnt have cooling issues in stock form.
    Dec 2009
    Thanks Witzl. Its a pretty frustrating job having to get the sandwich plate and run the lines, not to mention changing the sump over etc. Especially since I want to try get the car going soon its one less thing to go wrong and worry about atm haha
    oregon
    http://www.mr2oc.com/showthread.php?t=468649
    Tons of info... near the end of that long thread is some interesting experiments with oil temps and cooling.
    Oct 2009
    Eh, water to air is the way to go in a AW11.
    Cant fit your massive 30 row oil coolers etc
    Jul 2007
    you mean water to oil, and yes, air coolers are a pita to fit in an aw11 engine bay
  1. oil cooler+4age
    Last Post: 04-04-2006, 05:01 PM
