pretty sure it should be ok, might run a bit ritch, someone might be able to clarify
aftermarket ecu?
the ecu should sense that there is no longer extra air in the engine, either via manifold pressure sensor or air flow meter, which ever one you have, and adjust the fuel accordingly providing when it was maped they played with the no boost side of things.... hopefully
std ecu?
should work on similar theory but would probably worse off
