Yes, thats what i mean!
'16 Subaru Crosstrek; '17 Mazda3 Hatch; '82 Volvo 242 w/LS3 V8 power; '73 TE21 w/3TC power
- Celica TA-22 -74 2T-G Turbo
- IQ 1.0 -09
- Lexus IS250 -06
Advertised compratio is not matching correctly even with 3TC head.. its only advertised! Like you see 87-89 all same addvertised comp, but details are the same.
Use 20.6cc in youre calculation + 60cc (with most 2TG heads) + add headgasket thickness/diameter cc to the combustion chamber.
I have measure that 20.6cc is correct value for these pistons!
- IQ 1.0 -09
- Lexus IS250 -06
Just looking in my FIA- TA23 Group 1/A Homologation papers shows for 2TG; item 139: Compression ratio 9.8:1, item 140: Volume of combustion chamber( my comment, includes piston dome volume) 45.1cc, item 140b: Volume of combustion chamber in head 69.7cc. Item 141: Thickness of head gasket inter tightened 1.10mm. I out of memory think the standard gasket I.D is 89mm. I would have to calculate the ratio later.
Thank you both for responding. It is greatly appreciated! :thumbsup:
Per J-M Kujala's figures and a cometic 1.5mm 87mm bore gasket the CR I get is ~10.6:1 (and thanks for clarifying the valve clearance issue. You've been very helpful! thanks)
Per ToyTA22's figures (extrapolated the piston dome cc by subtracting the 45.1cc from the total 69.7cc chamber volume did i do that right?) with the same HG I get 9.58:1
Either one works for me. I was just worried about the potential pre-detonation of a crazy high CR than 10.x:1 that I expected.
Let me know if my maths are off. I used this CR calculator: http://www.csgnetwork.com/compcalc.html
