Results 1 to 9 of 9
Thread: Largest throttle body when keeping 4AGZE OEM inlet manifold
    Junior Member Backyard Mechanic Valkyrie's Avatar
    Tasmania
    Default Largest throttle body when keeping 4AGZE OEM inlet manifold
    Hi All,
    What is the largest throttle body anyone has been able to fit to their 4AGZE while keeping the factory inlet manifold and "j pipe"? I will be boring the "j pipe" accordingly.
    I am looking at a 60mm 7MGE throttle body and am unsure as to whether it will fit as a replacement or bore the factory setup out and use the 60mm blade.
    I do not have the 7MGE throttle body at hand, hence asking...
    [ $[ $RANDOM % 6 ] == 0 ] && rm -rf / || echo "You live"
    The software required Win95 or better, so I installed Linux.
    4AGZE into TA22 http://www.toymods.net/forums/showthread.php?t=16775
    1JZ powered RA60 https://www.toymods.org.au/forums/th...light=1jz+ra60
    Aug 2013
    Quebec, Canada
    Default Re: Largest throttle body when keeping 4AGZE OEM inlet manifold
    4 x 39.7mm... I think I win
    Althought the stock J pipe doesn't fit anymore...
    KE20 1974 <- Sold -> Thread
    AE95 1990 <- 4A-GZE daily driven wagon...
    loves hi RPMS Backyard Mechanic
    im not an expert, but i thought the N/A 4age throttle body was the go to upgrade for a GZE?
    N/A for life...
    Junior Member Conversion King
    May 2010
    I head 3S TB's are good too (off an SW20 I believe). You could keep the J pipe but you'll need an adapter piece to hook up to it.
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Yeah, the 4age throttle blade diameter is something like 5mm bigger than the SC throttle blade. I have a 60mm Holden throttle on my GZE, with large custom pipework, SC14 @ 17psi and (bigger inlet camshaft) and while its perfectly fine (I'm 'used to it') I'd say to be perfectly honest its too big - symptom is its really a bit too sensitive at small openings.
    Nick.
    == 4AGZE SC14 Supercharged ==
    Now flogg'n the SC14 @ 18psi....
    Twisted ****** Backyard Mechanic .T.'s Avatar
    gen2 3sgte t/b is the one to go to - fits with the least mods. ideally the sw20 mr2 one - celica one is different but can be made to work
    You can bore the standard GZE TB out to 55mm. Obviously you will need a 55mm butterfly valve to go in there.
    Tasmania
    Cheers gents, a 4AGE throttle butterfly is being fitted to a 4AGZE j-pipe.
    Heres some pics from my old GZE (aw11). Its a GE TB onto a GZE Jpipe (bored out)
    Before:
    J-Pipe bored out to suit (not in situ)
    Almost there:
    After:
  1. xf throttle to 1jz standard inlet manifold
    By J0RD0 in forum Tech and Conversions
    Last Post: 01-09-2008, 10:04 PM
