Results 1 to 7 of 7
Thread: 18rgu compression rating
    Jun 2012
    Default 18rgu compression rating
    Hi all I was wondering what is a good compression reading for an 18rgu?
    Jan 2012
    Finland
    Default Re: 18rgu compression rating
    Err.. you mean compression pressure;not ratio?
    If pressure the BGB gives 12,7 bar as std and 10 bar limit.These for 9,7:1 comp 18R-G;for 18R-GU somewhat less (being lower compression model)
    Sydney N.S.W
    do you mean the piston combo like 18rg=9.7.1 18rgu=8.7.1 and 18rgeu 8.3.1
    o
    Jun 2012
    Well the compression ratios were helpful but the pressure was what I was after thanks as I did a comp test and got fairly bad readings.
    Aug 2009
    Depending on the compression ratios, a good engine will give a compression reading between 140 to 180psi and no more than 10psi from lowest to highest.
    On an old used engine, if the lowest is 145 and the highest is 155 then it's OK. When I rebuild a motor, I aim for zero variance.
    Rgds, Willofan
    Jan 2012
    Finland
    Bad readings? So be prepared to shop valves..
    Jun 2012
    Readings were
    1:133
    2:97
    3:135
    4:126
    Then I did a wet compression test and the readings were
    1:165
    2:200
    3:190
    4:160
    So I'm thinking most likely piston rings?
  1. 18rgu compression
    By bholmberg in forum Tech and Conversions
    Last Post: 06-05-2010, 10:59 PM
  2. Replies: 24
    Last Post: 13-01-2010, 09:53 PM
  3. T50 Power rating
    By Muzo in forum Tech and Conversions
    Last Post: 31-12-2008, 07:59 PM
  4. compression rating on a piston
    By samoo in forum Tech and Conversions
    Last Post: 08-05-2007, 04:35 PM
  5. 20v compression (compression test)
    By 2revup in forum Tech and Conversions
    Last Post: 20-03-2006, 05:06 PM
