Results 16 to 27 of 27
Thread: The Conundrum that is the 1UZ - Fuel Economy and smooth running/flat spot?!
    Feb 2012
    Default Re: The Conundrum that is the 1UZ - Fuel Economy and smooth running/flat spot?!
    Quote Originally Posted by George View Post
    nathanshnoz could you check VF1/VF2 voltages when the engine is heated to operating temp and gradually revved through the rpm range you typically use?
    2.25V would indicate either perfect engine condition , or some failure in fuel mixture monitoring. The thing making me believe there's some failure is that both voltages (which indicate fuel trims for bank 1/2) are ideally matched, though in old engines the difference between the banks must build up.
    I'd advice that you at least emulate the sub o2 heaters so ecu won't flash sub o2 codes. For some reason fuel consumption is sensitive to sub o2 sensors
    I will check voltages tomorrow mate and let you know. How do you emulate the sub O2 signals? Ill double check fault codes
    Also I have a spare ECU, so I have tested with both and there does not seem to be a difference
    “Speed has never killed anyone, suddenly becoming stationary... that’s what gets you.”
    Jeremy Clarkson
    Nov 2011
    Might have your answer, doing another 2 at the moment with stock ECUs to get them engineered and regoed. Giz a yell at your leisure
    His. 2005 GRJ120 Prado VX
    May 2010
    Moscow
    Quote Originally Posted by nathanshnoz View Post
    I use electronic emulators. I'm sure ebay has a number of them. Any Toyota/Lexus ECU up to ~2003 is fooled quite easily, so even the cheapest ones would work nice. To run them successfully, you need to make sure the main sensors are ok, and additionally emulate sub-o2 sensors' heaters with resistors.
    Feb 2012
    4th surf I sent you a PM mate.
    George I have had a look on ebay and can't seem to find them
    Jeremy Clarkson
    May 2010
    Moscow
    Nov 2011
    gee at those prices for simulators u might as well fit proper rear o2s
    ive done shitloads of 1uzs and afew were the ones where which run rear o2s and never ever have hooked the rear o2s
    and never have had complaints about fuel economy
    can anyone confirm 100% that missing rear o2s is the issue
    the reason rear o2s started being used is so the ecu can bring on the check engine light when the cats fail when there is too much difference
    the before and after o2 readings
    fk the 1uz off and fit a 6lt ls2 atleast u can turn the o2 sensors off hahahahaah
    May 2010
    Moscow
    Mine add only $42 when installed along with immo bypass but I don't sell things at ebay hehe
    Mate's LS430 (european market model) ran worse and had the warning light on when only downstream sensors' heaters failed (both within a week, surprisingly). My emulator worked for the car, though being cheap and simple. Post 2003 cars often require more sophisticated emulators, I think those on ebay are that.
    Feb 2012
    I ran the engine check codes and only get code 21 at the moment which I believe is left primary O2 sensor. Can anyone confirm which side (physical) is the left side? (Passenger or drivers?) O2's are
    Only a couple of months old so seems strange if one is not working. Unless the plugs are damaged.
    Jeremy Clarkson
    May 2010
    Moscow
    sensors are located at both driver and passenger's sides
    there's total 4 of them. Each bank has 2: upstream and downstream sensors, called primary and secondary respectively
    bank 1 is located on driver's side on lhd vehicles
    if the code appears immediately after reset (battery disconnect) then it's heater circuit that failed
    Feb 2012
    ok I DO NOT HAVE SUB 02 sensors fitted.
    i have never had them fitted. my understanding of sub O2 sensors is the same as dumbass above. perhaps they do make a huge difference and perhaps they do not. at this stage i am not willing to go out and spend lots of money on sensors unless someone can convince me this is going to be the problem. i think the problem may lie elsewhere. we are talking about 20L per hundred Km's type stuff here and that's not driving hard at all so i find it hard to believe not fitting sub O2's makes a difference of 5/6L per hundred kms.
    Jeremy Clarkson
    Nov 2011
    Get your main o2s working
    Wire up the half moon diagnostic plug and get a scanner, live data is much easier to understand
    My hilux which was 50 to 55 lt tank got 300 kms distance on a tank
    So yours ain't that much worse
    People should really come to terms they are not a good motor overall when fitted to a 4wd or similar
    Nov 2011
    I could drive mine hard or soft and it used the same fuel
    Diff ratio plays a huge part on fuel economy of these motors
    Plus I've also had a friend with hilux but he had a 1j and he lost heaps of
    Economy when he changed his diff
    Doing 2500 rpm at cruising speed uses less fuel than 1500 rpm at cruising speed
  1. ST215 flat spot
    By scottlefevre1981 in forum Tech and Conversions
    Last Post: 17-10-2009, 07:06 PM
  2. Stumble off idle when cold, flat spot
    By leideno in forum Tech and Conversions
    Last Post: 27-07-2009, 06:28 PM
  3. 1JZ Flat Spot... Help??!!
    By Danners in forum Tech and Conversions
    Last Post: 01-08-2007, 09:32 AM
