The hose from the rocker cover should go underneath the air cleaner base. Not sure about the vacuum hose from the carby base but maybe charcoal cannister. the fitting at top of carby near throat of carby goes to charcoal cannister and is only a fuel bowl vent. the other brass fitting with a nut holding it on is for the automatic choke which would of had a pipe running to the exhaust manifold to heat it up.
