Results 1 to 15 of 21
Thread: Why she no run?!!? =[
    Aug 2013
    Texas
    Default Why she no run?!!? =[
    lol SOLVED
    Power at the injectors
    Sparks
    and motor is getting fuel
    Engine Codes 14, 24, 31
    1991 Cressida mx83
    jzs161 2jz-gte
    Aug 2013
    Texas
    Default Re: Why she no run?!!? =[
    errrrr just tried to change the title to something helpful but I can't =[
    are you sure the engine is getting fuel?
    I'd try running it with the AFM unplugged as opposed to a GE AFM to be honest!
    Pull the codes is the first thing to check (Tc to E1, then a light bulb between +B and the W pin in the diag box...)
    Also you haven't given a whollllleeeee lot of details in your post here (i.e. 2JZGTE VVTi from what engine, in MX83, stock everything? etc, etc) :S
    Wilbo's JZA80
    Wilbo's JZZ12
    Oct 2009
    Jigga the fuel pump so its always on and see if it runs?
    Sounds like the ECU is not powering the pump when its seeing a RPM signal - AFM fault etc
    Apr 2011
    make sure the fuel lines are the right way around, and check earthing. the ecu uses a ground from the engine to fire the injectors, if its loose or has a bad connection it wont start,or show any error codes. just had the same problem with a mates 1jz ra23 conversion!
    Aug 2013
    Texas
    Quote Originally Posted by wa5 View Post
    If i undo the connector and hit my fuel pump switch it pisses gasoline everywhere
    Quote Originally Posted by wilbo666 View Post
    JZS161 in MX83 all stock
    Fuel pump rigged on a switch.
    Quote Originally Posted by dnegative View Post
    Yes.
    It feels like the ECU is telling the injectors to start but not to flow while running, not sure if that is even possible but... ya.
    Sound like something with the COR or main engine relay?
    Aug 2013
    Texas
    Aug 2013
    Texas
    http://mkiv.com/techarticles/engine_...bd1_codes.html
    ^hopefully these are representative
    14 - Ignition Signal Circuit
    24 - Intake Air Temp Sensor Circuit
    31 - Air Flow (or MAP) Meter Circuit
    This is with the MAS/afm unplugged
    Nov 2011
    how the fk is the going to run right with no power to +B and +b1
    also pretty sure they r semi fly by wire so check for power at the ECTS or what ever it is at te ecu
    get a noid light and a spark tester so u can atleast test the very basics of any internal combustion engine
    also test for 5v at the tps as this will tell u if ecu is turned on
    sounds like your over your head but final test is get some aerostart and spray it down throttlebody and see if it starts
    Oct 2009
    Quote Originally Posted by 2JZmx83GTE View Post
    I have no power at +B, +B1, nor BATT. ( should've mentioned this at the beginning )
    That's like trying to start a car with no battery lol
    Nov 2011
    hehehe
    I have seen a 20v run without the small 3rd plug which powers the ecu
    so that's y I didn't say it wont start without that plug
    anyway he needs two wires that need battry
    and then mrel hooked up
    and igsw hooked up
    and +b +b1 hooked up
    Aug 2013
    Texas
    Aug 2013
    Texas
    Well, I had COR trigger grounded as stated on another forum but if I give it power then I get power at +B +B1 and BATT...
