Results 16 to 21 of 21
Thread: Why she no run?!!? =[
    Nov 2011
    Default Re: Why she no run?!!? =[
    sounds like an abortion
    have u got good diagrams
    when wiring any motor into a Cressida nearly all the wires are already behind the glovebox
    anyway good luck with it because sounds like u are doing it the wrong way
    Aug 2013
    Texas
    Awesome!!!
    Aug 2013
    Texas
    lol SOLVED
    Nov 2011
    why don't u go back to basics
    does it have spark
    put a noid light on injectors does it blink
    if u have spark then spray something flammable down the intake and see if she tries to start
    if it starts then u have fuel problem
    those diagrams don't mean much because we don't know where u hooked them up to
    the air flow and air temp errors wont stop it from starting but the 14 might
    if injectors are not pulsing u either have immobiliser ecu or u have wires shorted or no power to injectors
    causing injectors not to pulse
    is300 2jzge have immobiliser so if this is your engine then that might be your problem
    Administrator Backyard Mechanic
    Jul 2009
    Have u powered the BM pin on the ecu to constant power.
    My jzs171 won't start without it connected.
    You could also have an immoboliser ecu which would have the same symptoms.
    Aug 2013
    Texas
    Nope, no immobilizer.
    +BM (ECU) has power from BATT ( T5 cressida )
