errrrr just tried to change the title to something helpful but I can't =[
lol SOLVED
Power at the injectors
Sparks
and motor is getting fuel
Engine Codes 14, 24, 31
1991 Cressida mx83
jzs161 2jz-gte
are you sure the engine is getting fuel?
I'd try running it with the AFM unplugged as opposed to a GE AFM to be honest!
Pull the codes is the first thing to check (Tc to E1, then a light bulb between +B and the W pin in the diag box...)
Also you haven't given a whollllleeeee lot of details in your post here (i.e. 2JZGTE VVTi from what engine, in MX83, stock everything? etc, etc) :S
Jigga the fuel pump so its always on and see if it runs?
Sounds like the ECU is not powering the pump when its seeing a RPM signal - AFM fault etc
make sure the fuel lines are the right way around, and check earthing. the ecu uses a ground from the engine to fire the injectors, if its loose or has a bad connection it wont start,or show any error codes. just had the same problem with a mates 1jz ra23 conversion!
If i undo the connector and hit my fuel pump switch it pisses gasoline everywhere
JZS161 in MX83 all stock
Fuel pump rigged on a switch.
Yes.
It feels like the ECU is telling the injectors to start but not to flow while running, not sure if that is even possible but... ya.
http://mkiv.com/techarticles/engine_...bd1_codes.html
^hopefully these are representative
14 - Ignition Signal Circuit
24 - Intake Air Temp Sensor Circuit
31 - Air Flow (or MAP) Meter Circuit
This is with the MAS/afm unplugged
how the fk is the going to run right with no power to +B and +b1
also pretty sure they r semi fly by wire so check for power at the ECTS or what ever it is at te ecu
get a noid light and a spark tester so u can atleast test the very basics of any internal combustion engine
also test for 5v at the tps as this will tell u if ecu is turned on
sounds like your over your head but final test is get some aerostart and spray it down throttlebody and see if it starts
hehehe
I have seen a 20v run without the small 3rd plug which powers the ecu
so that's y I didn't say it wont start without that plug
anyway he needs two wires that need battry
and then mrel hooked up
and igsw hooked up
and +b +b1 hooked up
Well, I had COR trigger grounded as stated on another forum but if I give it power then I get power at +B +B1 and BATT...
