Results 16 to 22 of 22
Thread: BHG # 8 Information wanted on easy non turbo engine swap in a 1990 MX83 please
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default Re: BHG # 8 Information wanted on easy non turbo engine swap in a 1990 MX83 please
    Quote Originally Posted by cambelt View Post
    Hi
    The reason 7 m,s keep blowing head gaskets is the heads have all gone soft and machine shops often will pass them with a hardness of 75 brinell .
    For a 7 M no less than 100 brinell , machined block and head with a stock head gasket , then retention it after 5000 Klm and it will last 200 000 Klm . You do need to check for cracks between the head bolt holes and water jackets too.
    Dave
    This 100%
    My 7M did 3, and on the third, I did all this with a full rebuild. It's completely bulletproof now.
    vic
    Hi ujw
    What was the hardness of your head they tested ?
    Dave
    Tasmania
    I did my Cressie about 2yrs ago.I got a monotorque gasket for memory,machined out the blank for the rear water jacket at the back of the head and torqued it to 70 ft/lbs and haven't had a problem.
    Cheers Brett.
    May 2010
    Hi Dave
    The gauge they use is from ACL and doesn't use a numerical reference. Depending on where a ball bearing bounces against a scale in a tube it is either good or not. Mine was 50% up into the good range.
    May 2010
    In regard to the 2JZ-GE I have been told:
    a) I need a 2JZ bellhousing to use my auto.
    b) The solenoids and speed sensing will PROBABLY be different.
    c) The 2JZ-GE engine can be picked up with an auto and ECU for $800~
    d) I will need the original key and amplifier to the car/ECU or will need the ECU flashed.
    e) The conversion will cost $3000-$6000.
    Can anyone help that HAS done the conversion and still has functioning Air con, cruise control etc?
    Feb 2012
    Tasmania
    I took my ac out. my conversion cost $2800 including s13 radiator, new water pump and timing belt, new plugs $20 each x 6.
    I think your best bet is to get a 2jzge with an auto attached and slap the whole thing in then run your 2jzge off the 2jzge loom. This way you have complete control over your auto box it will make wiring simple, all you will need to add is drive shaft mods. but idk how hard it is to run a different engine with an auto so that could all be wrong haha
    May 2010
    Thanks 1G-GTE
    That sounds like a better option.
  1. information on which engine to swap in to a 96 toyota camry
    By sikwitit in forum Tech and Conversions
    Last Post: 23-10-2009, 09:24 PM
