Results 1 to 15 of 17
Thread: 2JZ Injector Q
    Default 2JZ Injector Q
    Real Quicky. I remember reading somewhere that the US 550 Injectors are high impedence and a direct swap for the 1JZ, am I right or am I just making S up in my head?
    JDM are 440 low imp and ceramic turbs, US 550 high imp and steel wheeled turbs?
    Malicious
    Default Re: 2JZ Injector Q
    Search ...
    The Purple/mauve 550's US spec injectors are low imp and require the US resistor pack or you can make up one yourself to do the job.
    2.9 ohms , and you need 13.8 ohms to run in your 2JZ.
    440's are 13.8 ohm high imp
    550s are low
    330's if your a N/A
    Dang must of been making S up in my head. So what are the 440's from? JDM 2jz?
    Malicious
    Junior Member Domestic Engineer psychofox's Avatar
    yep the JDM 2jz inectors are 440cc, grey top and are high impedance
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    Quote Originally Posted by psychofox
    Yup, what he said, US spec ones are low impedance
    Ar cool so I got it mixed up. Cheers guys!
    Malicious
    Montrose
    I'm actually looking for some low impedance ones at the moment, thing is doing a bit of web searching seems to show BOTH as being the case - usual web consistancy... It also seems that all the drop-in replacement injectors are high impedance. Can someone clarify impedance from actual experience, not just something they read on a forum someplace?
    US 2JZGTE diagrams show a resistor pack, therefore Low Impedance - 1994 Supra apparently
    I imported some Sard 550's HKS 550's and Blitz 550's all were low impedance. I sold them all as i didn't want resistors.
    P.E make the high imp drop ins as well as Sard, just make sure you get the part numbers correct as Sard make low imp as well.
    I can confirm 100% that JDM 2jz 440cc Grey top side feed are High impedance (13.8ohm). I owned a set for a brief period - was going to put them in a 20V 4AG rail - before selling them. I tested them with a multimeter. USDM 2jz I can't personally comment on but the overwhelming evidence on the net seems to say they are Low impedance.
    I also own a set of Gen 3 3SGTE injectors - red top side feed 550cc, as fitted to the sw20 MR2 and st205 gt4 and they are low impedance.
    Current Cars:
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Any idea if Aristo injectors are 440cc also? What about VVTi 2JZs?
    Yep 440cc. both of them. The vvti has pretty pink ones ....
    Unhappy Re: 2JZ Injector Q
    Thanks for that.
  1. 550cc US 2jz injectors into 1jz
    By Esselte in forum Tech and Conversions
    Last Post: 26-07-2007, 02:18 PM
  2. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  3. fitting a 1jz or 2jz into a vl
    By 2jzcalais in forum Tech and Conversions
    Last Post: 05-06-2006, 09:15 PM
  4. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
  5. 1 and 2JZ idle stepper motors
    By dori dori in forum Tech and Conversions
    Last Post: 03-03-2006, 02:24 PM
