Results 1 to 7 of 7
Thread: 3TC Clutch Kit Fit A 2TG Flywheel???
    Aug 2011
    tipperary
    Default 3TC Clutch Kit Fit A 2TG Flywheel???
    Would this 3TC clutch kit fit my 2TG engine/flywheel?
    http://www.ebay.com/itm/AUTOCOM-Stag...8132f5&vxp=mtr
    Default Re: 3TC Clutch Kit Fit A 2TG Flywheel???
    Hi there mate,
    I believe it will fit. For best results you would want to be getting your flywheel freshly machined of course!
    Jason
    Aug 2011
    tipperary
    Thanks Jason
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    The difference between 2tg and 3tc flywheels regarding clutches is the clutch engagement area, which can be machined bigger or smaller to suit when the flywheel is resurfaced.
    Nov 2007
    Tasmania
    That clutch is pretty cheap, even with the postage. Might be a bit aggressive for street? I was looking for a clutch from the USA. Cheaper, but the postage is usually way over charged.
    I recently tried to put a new T18 clutch to a 3TC and couldn't fit the pressure plate to the flywheel because of the different dowel pattern. Then I noticed the old clutch was smaller, i.e. 190mm instead of 200mm. Someone must of changed it to a 2tc clutch. Not sure if the 2tg flywheel has different dowel locations as well?
    Aug 2011
    tipperary
    Thanks guys.
    It's a rallycar with sequential gearbox so need strong clutch.
    Jun 2006
    Yeah I was under the impression that t series dowel patterns are the same, except for 3tgteu which uses
    a larger flywheel and clutch if its the w55 box and not the t50 box version. Thats what I seem to remember anyway.
  1. 1JZ clutch and flywheel ???
    By mx73 in forum Tech and Conversions
    Last Post: 27-11-2009, 10:25 PM
  2. 1G flywheel/clutch
    By Big rob in forum Tech and Conversions
    Last Post: 24-02-2006, 04:31 PM
