Gday I am doing this same conversion right now and I used a 2jzge clutch kit from exedy
part number TYK 7332 HDB and a 2jzge flywheel and also swapped the bellhousing to 2jzge all fits together nicely but haven,t driven with it yet.
Hope that helps![]()
ok so i just bought a mx73 and a 1jzgte with a w58 now the problem i have is that i need a flywheel and clutch before i drop it in .... so my question is which clutch and which flywheel should i buy i have about $1000 usd saved up. i don't mind using a lightened flywheel i was looking at fidanza as a possibility and i was also looking at ACT clutches and such but again i;m not sure which is the correct combinations i'm trying to stay within budget and i'm just gonna run my motor stock with the twin turbos for now until i can afford a single turbo set up laterany help would be much appreciated ...
also i know that this is a toyota forum so i'm going to post a link to a short 2 1/2 minuted video i made of my friend Chris Scremin driving his ae86 corolla with an SR20hope you all enjoy
http://www.youtube.com/watch?v=EKaiQAqysd4
thanks again
is the 2jzge and 1jzgte compatible ?
Sure is all bolts up smooth.
what about cost for the parts ?
Clutch kit was $630 AUD flywheel $300 second hand and $50 to machine flywheel bellhousing was not cheap at $400 second hand and was not so easy to find.
Thanks for the info adz I ended up buying a clutch and flywheel from a 2jz na that I found locally so I didn't have to spend the money on shipping I had the bellhousing for the w58 from the motor I (came with motor and trans w58 bell housing) that's why I has the clutch/flywheel question thanks for your help ...
No probs happy to help.
You planning on drifting this car?
yeah thats the plan maybe one or two events next season tops since i'm a photographer/videographer first and then a drifter ... i had an s13 hatchback dohc KA dropped on 18's but my buddy got a toyota crown and i fell in love with 4-door sedans, then i saw the cressida and was like i want me one of them ... so i picked up a mx73 brown super mint shell with no motor for like $300 and i picked up a 1jz with the w58 and all the goodies except intercooler and rad for like $1800 my next big buy will be suspension parts from serial nine they use stance coilovers with custom adapter plates or something to that effect i'm still not sure how there system works but i was thinking of posting it when i get my set up from them and then i was also thinking rims maybe some wire wheels just to look like a baller ... haha
Sounds good.
The coilovers from serial nine look good but pretty pricey especialy over here think I will have to make my own from one of the kits that are on the market.rears are a pain in the arse but going with low springs and shocks for now.
