Results 16 to 23 of 23
Thread: Yet another 7mgte mx83 conversion, mz21 yellow plug identification
    Nov 2011
    Default Re: Yet another 7mgte mx83 conversion, mz21 yellow plug identification
    hi yes I got email this arvo but had to duck out to fix a breakdown
    might be easier to send me the new loom and the old one and I can sort it out as it would be a bit cheaper
    as long as the looms havnt been touched or cut up to much
    because im driving down from Brisbane to Sydney and i wont be able to come down to woolongong
    I do have a 7m ge auto ecu and I do have a 7mgte auto ecu
    and I do have a plug for the auto ecus which is usable
    Sep 2013
    New south wales
    So will u sell me the 7mgte auto ecu and plug? I think I may have worked some of it out, we'll the main plug that has the thick wires that is, I would post a pic of the other plugs I have but unsure how to post pics off my phone
    Sep 2013
    New south wales
    Can anyone please help!!! I've been trying to add a picture of the main plug I'm having trouble identifying! It's yellow and has 19 pins and is 2 rows and about 2 inches long... Also it's from a mz21 soarer, not sure what year model tho, is it possible it's from the get special edition I have read about?
    Nov 2011
    120 bucks posted if u want ecu and plug
    The plug has about 3 or so inches or wire length but it has had solder joins about 10mm from plug
    So it's usable
    Sep 2013
    New south wales
    Ok this one is for anyone...when it's talked about the t5 pin do i re pin it in to the corrosponding location on my 7mgte ecu? Ie pull the pins out of the ecu plug or piggy back the Cressida t5 pins on to the wires that already come out of the gte plug... If that makes any sense lol
    Sep 2013
    New south wales
    Ok so I got most of the wiring done! Has spark but no injector pulse! Will start with a sniff of aerostart lol
    Sep 2013
    New south wales
    Ok another question lol should my fuel pump run constantly when the ignition is on but engine not running?
    p00 powar Grease Monkey Jin~Jah's Avatar
    From a safety point of view, probably not.
    Function wise, it depends entirely how you've wired it up - it is possible to wire a relay for it that's controlled by the stock fuel pump trigger from the ecu.
    Having it wired to ignition definitely works though, it's how mine has been since I planned out the ecu trigger and then never followed through with it
  1. mx83 7mge manual conversion info needed
    Last Post: 06-04-2016, 01:32 PM
  2. 7mgte HD clutch needed ASAP
    By Kedderz in forum Tech and Conversions
    Last Post: 26-11-2007, 02:48 PM
  3. 3s rwd conversion parts, what else needed?
    By CoronaC in forum Tech and Conversions
    Last Post: 11-01-2006, 07:43 AM
